What I am saying is that the vortex here is BP ultimate. Its actually 98 ron bp fuel.
The reasoning this guy gave me for caltex not calling it vortex 98 is because the real ron figure can be anywhere between 95-98. BP dont care that its often lower then 98, but caltex promise it to be atleast 95, hence the 95 ron rating.
I still find it all a little wack, were the catlex premium pumps running out at the same time as BPs?
Edited by noise
Here is some other things people have heard, or know:
  Frink said:
i heard somewhere that Vortex 98 is just re-badged Optimax...... :D
  dezzabye123 said:
vortex 98 is coming out of the distillation at over 100ron and then is blended down to met specs..
I used vortex when there was no ultimate and some caltex's were running out. Attendant said that they wouldn't have any until middle of december, thought it was a bit of a coincidence that it was the same time ultimate was meant to be back.
Maybe our vortex is just ultimate that's been cut with lower grade fuel to make it 96 ron.
I've visited Dulux factory and apparently they manufacture competitors paints as well (a specificed ingredients list is provided by the compititor), because it is relatively expensive to buy the machinery, so competitor just 'piggy back' of Dulux...this is why even though more ppl chose to buy rather cheaper generic brands, Dulux never went bankrupt...
imagine that there is only 1 refinery in W.A....so the companies, BP, caltex, other fuels basically come from the same spot, only that different companies have their own "secret ingredient" such that the refinery have to refine these petrol according to the clients specification.
now what if the refinery is owned by BP....BP will process fuel for the competitor..and the competitor sell cheaper fuel ... However, BP needs to keep it's image up..and hence they produce the only 98 Octane Fuel in W.A....BP domination...muahhaha
probably in the case of Eastern State, the amount of population is enough for each individual companies to set up their own refinery and keep it profitable...therefore 4 different 98 octanes to choose from... BP does not dominate the market anymore....
This checks out with the unavailabity of vortex in the same timing as Ultimate...but then again I might be wrong...don't have the fact sheets on me....
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
