UPDATE
For those of you who have emailed me you'll also be getting this sent to your email address. However for those who haven't yet emailed me please do so with this information:
Forum:
Car:
Name:
Contact #:
We will be asking for deposits in the next day or two, I will contact everyone on my list either via email or phone to give you the bank details.
Cheers
Brett
  • Replies 157
Posted Images
oops ignore that ok and is the price still $150 or is it less and how much deposit do you need?
Also thats a friday isnt it?
What time will you be starting?
Edited by 7yphon
Yeah price is 150 unless we get 40 people.
Deposit is 75 and i'll get the account details out to you soon... Yes it's friday 20th January looking at starting at 7.
Topaz: yeah shouldn't be an issue.
Edited by INSSSANE
The purpose for this track night is see how much interest there would be in running it on a ~2 monthly basis. If it ran smoothly and everyone was jumping up and down to enter then we were going to put it on the calendar as a regular event. However due to lack of seriously interested people this event is looking like being permanently cancelled. We currently have deposits from 5 people but for this event to still happen we require 20 deposits by the 3rd January 2006(extended from the 20th December2005).
I will let you know the status of the event on the cut off date and for those people who have sent in their deposits they will have them refunded.
Regards
Brett
Edited by INSSSANE
Get behind this people - there's not enough opportunities like this in WA too often!
Unfortunately financial commitments than come from just buying a house and being round christmas time is restricting me from entering otherwise i'd be there with bells on!
5 people have deposits!!! thats all? :)
If 20 people are needed by the 20th of december; its gunna be hard getting that many is 4-5 days now.
Sorry guys, I haven't submitted my deposit, but I might pull out anyway considering the circumstances and the likelyness of this event actually happening. Too bad, it would have been good :)
People have has more than enough time to get their deposits in, I sent out the information on the 8th Dec. I have just been given the instructions to re set the cut off date to the 3rd Jan 06. That's not the right attitude, if we get to this date and there are 19 deposits and you haven't sent yours in then the event will still be cancelled. At the end of the day you WILL get your money back if the event is cancelled.
Come on guys send in your deposits "For those who think there car wont be done, use this date as a goal to get it done by as I have"
Also ask you friends even those with crappy little datsons or ask your mum or dad im sure they have thought about it a least 1nse in there lives, This is for fun after all why not try and get everyone involved...
I see your point, but I have to book a day off work and I need all the leave days I can for a holiday in June '06. I'd need to know ASAP if this day is gunna go ahead and like you said, 19 people is not good enough :(
But I have your details and will transfer the money anyway to up the numbers just in case :(
EDIT: ok mate thats done, now I really want this to go ahead. Theres 20 people for the Motorplex night already....maybe its the cost :(
just do what i did and let your boss know anyway and tell him look Im not sure if it will happen but this is the date and it might go a head. He will like that.
ok, that sounds like it will work... :(
how many is it now then? 6?
:D:( :lol: :lol:
I was going come up for a gander. I really hope this event gets off the ground.
Hope the above comment is an invertation not an insult :) as I have posted this on OzDat.com Western Aust Events to help boost the numbers for you.
Good Luck hopefully see you all there on the night.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
