I had an HKS pod in my skyline and removed it when I got defected and noticed no difference whatsoever. I didn't even have an aftermarket panel filter. Of course there is the possibility that I did lose power but it must've have been so minimal.
So i'll be sticking with the airbox in the future, for daily driving I can't tell the difference and its alot cheaper too when the cops pop ur bonnet
i remember reading a comparison test on the filters (apexi, blitz, HKS and K&N)
and all gained around 14 BHP so difference isnt that much i know apexi was best for both filtration and power gain (best BY FAR for filtration, and 14BHP gain)
K&N was second best for filtration and was good power gain at 13.8 BHP
and actually HKS was worst by far filtration was SHOCKING and power gain was 13.6 BHP
so as for power gain you shouldnt notice that much of a difference
RellikZephyr
Yeah, but a pod, if its sucking hot underbonnet air, is going to reduce performance. Air box will win everytime, with the snorkel drawing cool air from outside the bonnet.
Dyno will not tell shit, of what happens in the real world.
If you want a pod, put it in a box, or setup a heatshield, and have the best of both worlds.
Well even if you can't notice it seat of your pant style,
You would get better performance and fuel consumption if the motor was breathing in ambient outside air, maybe up to 30degC, instead of hot radiated air from the motor under the hood that is 50+degC.
Not to mention it will help avoid detonation as well.
I would assume it depends on power being made.
My RB20DET 3years ago was making 164rwkw on 1bar, with the stock air box and stock filter and stock small cai snorkle.
The tuner grabbed his Apexi pod from his R33 and bolted it on to mine, ZERO power increase. Obviously done on a dyno back to back.
I have since placed a 100mm dia cai in to my inner bumper and chopped out the bottom of the airbox + some fibreglass for a nice smooth stock black finish. :O
Unfortunately you R33 ppls are unable to do this as your airbox is UPSIDE DOWN! :D
Edited by Cubes
How do Pipercross panel filters compare to say K&N / Apexi panel filters?
Thinking of ditching the K&N pod filter and reinstalling the R33 std airbox I picked up, but need a good filter for it.
Hate the sound the pod makes (too noisy) and it sucks hot air even with a custom enclosure (enclosure is always very hot after a drive).
Probally just because the noise has gone.
If V8's lost their noise, the owners would realise how slow they are too.
ROFL :lol:
agreed. I was gonna post same same, but i was beaten... again! :D
search button :(
SK done it all before on his finding
Cheers, I have done a search but I'll re-search then.....
I know SK rates them highly, just after other opinions (if any)
Pipercross cost around $59 + delivery whilst Apexi panel filters cost around $100 delivered.
Brendan
i changed my box without a snorkel(fmic blocking) to a pod with heat shielding, made no difference apart from the VERY ANNOYING NOISE!
so anyway since it has been sucking cold air the only positive thing i have noticed is that my idle used to sometimes go crazy and it barely ever does anymore so i think the AFM was being affected by hot air.
do you guys know, that autospeed done a test of pressure drops on a vl turbo intake system some time ago. (can get the url if you want)
they found a standard paper element filter to have almost 0 pressure drop (well not 0 but bugger all compared to the other restrictions in the intake system) the biggest restriction was the afm mesh, this was a huge restriction, compared to anything else.
the reason this is of interest is because im sure the r33 and r33 run the same air filter?
so expensive k&n may be ok, because you can wash them and re-use, but if you think the performance will be better, you are mistaken once again.
i always used genuine Nissan paper element filters, change every service and have no dramas. for me to buy a k&n, i would need a gun to my head.
if you are serious about removing restrictions, flick the mesh. do it to all my hotwire meters, never had any decline in idle quality, or smoothness. if anything i notice improvement in response and fuel economy. (some of you are parro about the mesh i know, but anyway, if you think the filter will have any performance gain, your joking)
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
