Ok so im not sure if its true or not but i heard that there is a locksmith that can cut the factory Nissan imort key (eg: for a R32 GTS-t) without having to buy a blank key from Japan.
Anyone know if its true or had it done and where abouts?
Cheers B
https://www.sau.com.au/forums/topic/95890-spare-key-cut/
You can buy the blanks from your good old local Nissan dealer. Nothing speacial about the keys, same as most locally delivered stuff. I brought as blank off Von Bibra's up he for my R33, cost not much more than $20. Then got it cut off the code number at the local locksmith.
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1735706
lol i got a key cut in burnie for my car the other day R33 didnt cost much think it was 5 bux i think. just a standard key though.
BTW wogboy have you been to Rosebery L8ly i think i seen your car down there not so lnog ago.
Edited by drumstick29
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1736331
Went through there a couple of months ago on the way to Strahan. Stopped and had a coffee. I went to school there.
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1738778
Was your car parked out Sth Rosebery. Saw a R33 out that way.
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1738785
Yeah $5.50 I think I got charged in Kingston, took about 3 minutes and works a treat!!
Well i got mine cut from Darren as well but it doesn't work <_<
Goes into the ignition fine, just wont turn :)
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1739057
Well so far i have had 3 keys cut at 3 different locksmiths and none of them work. All will go into the ignition but none will turn the car on.
Looks like im one of the unlucky ones and will have to pay $50 for a NISMO blank key :)
Cheers B
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1767840
Looks like im one of the unlucky ones and will have to pay $50 for a NISMO blank key :D
Cheers B
I noticed with my silvia keys (they obviously have been cut) they only work one way around, as in you put it in the barrel and it slides in fine but won't turn, take it out rotate it and put it back in and its fine!
also you barrel could be slogged out and isn't accepting a fresh cut key (how was the condition of the old one?)
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1769890
Yeah thats what i thought as well (more like hoping) but when Darren looked at the barrel he said it was fine, and that without the proper blank he wouldn't be able to match it up (or get it work).
So looks like if i loose my keys then im good and proper fooked :D
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1769902
hey b, got one cut for my car about a week ago... no problems at all :(
how does "go FARK urself" sound SAMMY BOY.
My stock car still will beat yours and thats all that matters...
Just dont steal my key or then im FOOKED :lol:
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1787235
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
