Hi all,
Just installed a hks 2835 pro s in my r33 - just thought I'd post up some pics of the install.
It took dad and I all day today from removal of the stock turbo to turn key new turbo to do the install.
The kit was pretty easy to fit - quite a bit fiddly getting everything fitting right though as there is a lot of adjustment - you can turn the compressor cover and turbine cover any way so it takes a bit of patience that's for sure.
The new intake pipe doesn't line up (miss by a couple of inches) with the stock airbox so we cut a short length off the standard rubber intake pipe and it fits ok - no problem for someone running a pod though.
Also took a some comparison photos of the stock rb25 det to 2835.
This was a great turbo for me - made good power and didn't miss a beat.
Will be puttering to the exhaust shop tomorrow to get the down pipe made and probably dyno later on in the week.
Something I haven't heard though is a turbo spin for ages like this one after turning off the engine.
Pretty cool - can't wait to get the tune done and see how it goes!
Cheers
https://www.sau.com.au/forums/topic/95914-pics-hks-2835-install/
  • Replies 109
This turbo is THE bomb. It is totally awesome for a low mount and internal gate turbo, and makes an absolute weapon of a street car. Prepare to fry your tires like never before!
heres my latest tune. The tuner was wrapped and said it was probably the best street car hes driven, which is a pretty big statement!
281.7rwkw at 17psi. Im told that this is pretty much the maximum for this turbo, which rated at 420ps, is making nearly 500hp at the fly. I know some have seen 300rwkw, but i think that may have been taking measures to hold shut the wastegate! Stock manifold and plenum by the way, only addition are good ol tomei 256 poncams as recommended by SK.
by the way i strongly recommend you make up something like this:
as no gasket comes in the kit, or is even available, and make sure to add a washer between the heat shield and the dump pipe around the top stud AND use some sealant, as we had a problem that the afforementioned washer fixed. (reason is the heatsheild flange is forked, not round, and air leaks from the stud hole out the forked bit of the heat shield bolt flange!
cheers
Hi Sly r33
Very impressed with the dyno result!
How are the new cams? Is the idle very different?
We used coppermix sealand on the dump - hope it holds up! A few people on this forum have recommended it.
Maybe the reason why you have a leak is that copper wire probably has a small leak where it has a break??
I'm just really hoping we have no problems otherwise it'll be hit the spanners again!!!
On a good note I took it for a drive this afternoon with the new down pipe installed along with tech edge lamda sensor unit - good to check the AFR's as I won't be able to get it tuned until next saturday. Man this new turbo comes onto boost hard, and it feels just as responsive as the standard turbo! I didn't go past 40% duty cycle on the injectors - the top end must be pretty impressive! Knock levels were fine too.
I just can't wait to get the tune done now.
Cheers!
the cams are great, no real noticeable change in idle.. i thought it sounded a little more throbbing/pulsing at idle, but its probably psychological as i hadnt heard it idle for ages, hehe.
its quite responsive, but its still pretty far off the std turbo! i think it feels more responsive because you get a heap of torque even while its spooling. Hits hard at 4k, but pulling way below that. I think any more lag and it wouldnt be such a good street turbo so i wouldnt consider any larger exhaust AR. Even with the .68 you can get caught just off boost round some slower corners, doesnt take long to build tho.
make sure you sort your diff out, as you want a controllable rear end when it bags them up! A worn out viscous lsd would be a bit sketchy to say the least.
when do you get your tune and whos doing it?
Good to hear the cams don't affect drivability down low.
I'll be getting my tune done next saturday (the 3rd) in Bundaberg QLD by a guy I've known for years - he worked with chiptorque for six years and has tuned more skylines than I've seen so he should be fine.
If I lived in SA I'd go to your tuner though as he's just tuned yours!
Did it take him long to do the mapping for the new cams?
I've been told it takes about four hours to get it all right.
I'll definately look into the diff - I'm not silly though and take it easy on the street.
Cheers
Reading this is really tempting me......this was the turbo I had planned to get orginally.
But after hearing a few cars I was determined to get a larger turbo with a screamer pipe......god I love that sound.
HI Shonen,
The good thing about this kit is you don't have to modify anything - everything just bolts up and if you want no bling (like me) you can even fit the standard airbox.
Screamer pipes sound good for sure but it'd get pretty annoying after awhile - especially if your wastegate opens in front of the police - the perfect way to get a defect.
And fitting a larger turbo on a custom manifold would be a nightmare - there's not that much space there - the only aftermarket exhaust manifold I'd go for would be a cast HKS item or similar.
Cheers
Correct me if i'm wrong, but don't you have to modify the dump for these turbos to just "bolt on"?
Or does the kit come with the modified dump in it?
VV ahh okay, thanks that's what i thought :P
Edited by Beeble
Sorry,
I was talking more about fit up to engine.
The kit comes with its own dump. The only thing that you will have to get is a new pipe made up from the dump outlet to cat. I got it made at my local exhaust shop for $150.
Edited by gtst25
hey, i just got a few question for you and SLY33.
So the turbo doesnt come with a gasket for the dump pipe? so you have to make your own correct?
Also with the HKS dump pipe that comes with the turbo (if u buy the kit), does it bolt into the stock dump pipe postion, as i've been looking into these and it looks like it is the same size as i normal dump pipe (in length) so if you have any aftermarket front-pipe that connects to the stock dump pipe, it would fit?
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
