not sure .... the dyno I had it on seems to be out by a bit and It said on 1.2 bar I had 320rwhp, but I've powered away from a R33 with 300rwhp ... So i have no idea. Hopefully I'll get it retuned in the new year and stick it on a decent dyno and get a more accurate figure.
  • Replies 109
Very interesting read....
Make me shy away from a GT30 again... I think this time ill do what you have done... Just with a new plenium (i like the tidy look with a front mounted throttle body)...
Thanks for the ideas...
Just got the car dynoed on saturday - the readout was a bit out I think compared with the dynos everyone else uses on this forum - peak power is 275rwhp!!
The car has been on two different dynos since I've had it and the first gave a readout in shootout mode (dyno dynamics) of 225 rwhp at only 10 psi at 5000 rpm - we couldn't take it any further as the fuel pump was buggered.
Then I installed a pfc, new fuel pump and on the same dyno we used on saturday I got a peak power reading of 210rwhp at 7000rpm - the dyno definately reads a lot lower than others as the car was going a lot faster.
On saturday we used 18 psi and interestingly the boost falls off after 6000rpm - we think it's my rear muffler which has a 2.5 inch pipe going through it so I'm looking for a bigger one now.
Driving the car has been a bit disappointing - you have to rev it to get going as a lot of timing has been pulled out where it comes onto boost - before the tune it had around 7 degrees extra timing in the midrange and it easily spun the wheels as it ramped up - no knock either so I'm wondering how it would go with a few degrees put back into the midrange.
I'm definately not frying the tyres like you slyr33 - last week I purchased some new 275 hankook 104's and they grip pretty well - it does have some wheelspin but not as much as prior to the tune.
Anyway all in all it was a bit of a disappointing day - next week I'm thinking about putting the car on the dyno we used the first time a year ago if I can get a bigger muffler on it.
Cheers
yes, that is dissapponting, either the tuner is missing something or you have a major restriction somewhere! the 2.5 inch pipe should not reduce power by THAT much! as the power your making isnt much better than a stock turbo can do, even if the reading is a bit low!
also you will find that the turbo wont hold boost over 6grand even if you remove your exhaust. i have a straight thru system and boost always drops back to 17psi at the top end. so dont worry about that, as you should still make lots of power at 17psi.
whos doing the tuning?
Just had a good look at the muffler - it's got a silly 7 inch tip on it which made the 3 inch pipe look small - so it's 3'' after all.
Glad that you get the drop off in boost too - hopefully there's no problems with my setup then.
Took it for a big drive today - stinking hot - I put back quite a bit of timing in the 10 - 14 load points at 2800 - 3200 rpm (ignition map) and have no knock - seems to get through that region a bit faster now.
I think I'll put it on the rollers this week for a quick power run or two to get a more accurate reading. That dyno must read low - hell you can get 275 rwhp with a stock turbo.
I'd be interested in seeing your pfc ignition and injection maps - I've put mine on microsoft excell spreadsheets and can post them up if you're interested.
Had a bit of a bad run in they last week! Got those tyres fitted and the guy at the tyre shop gouged one of my rims badly on the tyre remover - then on saturday at the dyno the dill who owns the place decided to do some spray painting at the back of the workshop - the dyno fan sucked the overspray in and all over the front of the car. You really deal with some dead heads at workshops. If they can't do the job without damaging your property they shouldn't be in the industry - hell when I was 13 I knew how far overspray can travel.
Cheers!
GTST25 can you send me you excell maps to compare to mine with the high flow setup.... Wanta see the differences...
If you print this off and goto your ignition map - maybe just write down the differences?
Also had trouble uploading straight from excell so had to print off and scan onto a photo program.
I think I've got a boost leak so am going to make up a couple of bits of pipe - one with a blanked off end and the other with a valve fitting so we can do a pressure test - it really feels like I've got a boost leak.
does anyone know if it's possible to buy just the dump pipe for this turbo? (if you dont buy the kit)
i dont think sooo.... :(
i just check the HKS website under Extension kit (aka dump pipes) and they only sell them for stock application
What load point are you reaching on your PFC map so we can align it with your ignition table
I haven't seen it go over load point 16. Normally it'll spike to 16 then run across the rev range on load point 15.
I'll post up the injection table too when I have a chance.
Pressure tested the pipework today to 2 bar and no leaks at all apart from the factory blow off valve which leaks all the time even with the vacuum hose connected through with positive pressure.
I tried dad's rb20det blow off valve and it was exactly the same - they don't leak much but do leak a bit all the time. Also tested the wastegate and it begins to open at .9 bar. We thought there must be a leak somewhere as before the tune we had the pfc boost control set at 40 duty cycle, 1.2 bar, but during road testing the boost fell away to 13 psi - we had to increase the duty cycle to 70 to get the 1.2 bar again.
Cheers
Cheers
If I get the 2835 pro-s turbo on it's own (not the kit) then I'll have to get a custom dump made.
by the looks of it yeap :( thou maybe email nengun and ask them as they sell the turbo by itself and the kit, so maybe they can work something out for you
Im not sure but you seem to be running very little timing at load point 16, like 14 degrees is nothing. Why dont you try and increase this (you can add 1 degree to the whole table and test it, watch for knock and move upwards, say 2 degrees, this should give you a nice increase in power) I dont think my timing drops below 19 and im running 20psi
lol.. m&m since i'll be using my car on the track for clubsprints.. i dont want a big laggy ass t04z. but thanks for the suggestion :P
Hey dude nice to see you finally got them rims.......im getting a set soon...in white though !
hehe as for the T04Z....mate its all about driving style. :huh:
Gaurage Saurus R32 GTR uses a T88-33D and still manages a 56 sec lap around tsukuba..
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
