I'll be getting my tune done next saturday (the 3rd) in Bundaberg QLD by a guy I've known for years - he worked with chiptorque for six years and has tuned more skylines than I've seen so he should be fine.
That would be stewart yeah??
Edited by 33SOM
  • Replies 109
i didnt have to modify my down pipe at all. My car came with a standard dump pipe, and ive since used an HKS dump for the 2530, and the HKS dump for the 2835 kit and they both bolted up without any mod. but then i must have had a different downpipe originally.
cheers <_<
i hope thats not sarcasm evilution.
ahah nah sorry i like that face it looks cool ;)
sorry, im general interested as im looking to get the same kit for my r33.
What would you advise to upgrade at the same time as turbo?
fuel pump, injectors, ecu, afm? you also mention something about the stock lsd, did u find with the new turbo the stock lsd, couldnt put the power down?
agains sorry for the missunderstand :angry:
lol, i wasnt sure as my last post was a little iffy trying to explain how mine fitted up..
without a doubt, you will 100% need an ECU like an fc, injectors, Z32 AFM and an upgrade fuel pump, and dont forget the clutch.
i found the stock lsd couldnt put the power down with a stock turbo let alone the 2835. main problem was powering out of corners, it wasnt so bad in a straight line, but still suffered a bit.
hmm, I bought my car already modifed and it has one of these turbos, only thing is I've got some custom made dump pipe - its not real flash :P ... can you buy just the dump pipe? Also what intake do you guys use to step down the to the Air Flow meter? Would one of the Apexi power intake kits with a 4" to 3" silcon hose work?
cheers
hey guys,
just wondering how much you both pay for the kits landed to your door if you dont mind me asking?
also, is the actuator rated at 1.2bar? If so is it possable to run lower boost like 0.6bar with a ebc and on that note how would you connect an ebc to the turbo, as its got 2 outlets; one on the turbo and one on the actuator do you need to get a T picese?
Cheers Michael :P
The wastegate actuator arm on my kit is adjustable - I didn't play with it though.
As for putting a T-piece in - we just blocked off the boost outlet for the wastegate and used the factory after intercooler boost outlet as we were worried about the Apexi boost control solonoid getting hot air directly from the turbo (probably would be fine).
I'm running 1 bar boost so not sure how you would go trying to run less but probably would be no worries.
Also I wouldn't get the dump pipe from Japan - it wasn't as well made as my original one - you're probably better off getting one made locally.
Cheers
SLY so you got that power with no modified internals?
i made 266rwkw on stock internals with 2 pounds less boost. i then dropped in a built motor with forgies for piece of mind, and added the poncams at the same time and made the 281rwkw. The stock motor wouldve easily made the power with just the addition of cams.
like all the HKS stuff ive had, the dump supplied with the kit was of awesome quality, why didnt you like it? it might look a bit crude where the wastegate pipe merges (looking inside the base of the dump), as it looks like flow will be impeded by the main pipe, but it seems to work fine.
Edited by SLY33
sly when does your boost come on and does it pull as it winds up
i dont know when it starts building but its pretty early, full boost by ~4grand.
does it pull as it winds up? do you mean as it builds boost is it still pulling? yes it does, wouldnt it have to?! Acceleration is still plenty for overtaking etc even when below 4 grand.
The dump is well made but:
I didn't like the dump for that reason - the lip where it joins the main dump must be a restriction and also my locally fabricated dump had a pipe extension from the dump turbo flange right to the turbine outlet - ensuring the wastegate/turbine gasses are totally seperated.
Another interesting point is the wastegate can only open about 10mm before it hits the dump - I don't know how it'd go it trying to control boost on a larger capacity engine. ie rb30.
I'm sure it works fine but I think it could have been done better - I wouldn't be sourcing it from the other side of the planet.
Cheers
:O i see 1.2 bar by about 3500rpm ..... what size cams have you got? I would have thought mine was laggier cause i have big cams - 270 with 10.25 lift ...
look at my dyno graph supplied and see how it compares with yours. you will have to convert speed to rpms. the ~ is the point in my post. "about" 4 grand. i dont watch the tacho and boost guage simultaneously (my boost guage is in the glovebox and used only to check boost occasoinally by a passenger), nor do i have a dyno sheet with rpms. when im flat to the floor im more wathcing the road than anything else but i know that when the needle hits about 4grand its pulling hard.
what does yours make peak with the 270 10.25 cams? mine are only 260 8.8's.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
