Got the car dynoed on a different dyno yesterday afternoon - no changes just a modern dyno dynamics dyno in shootout mode.
The 341.9 horsepower - in kw is 255rwkw - sounds much better than the 275 rwhp figure from the other dyno.
Interestingly the AFR's were reading differently between the units - the original tune was done with a motec and the tuner was tuning to afr's around 12.8 - 13.1 which I thought was lean - yesterday with the autronic lambda unit it was reading rich at 10.9 - 11.3 at full load.
We tried pulling a bit of fuel out but it lost power, then tried putting 1 degree of timing in - too much knock, then tried pulling out a degree of timing out and lost 20 hp.
The motec unit must read lean as at cruise with the o2 sensor switched on it was reading about 15.8, whereas the Autronic was reading 14.7 which is about right.
We didn't muck around with it - I just wanted to do a few power runs to get a dyno readout from a different dyno.
10 kw less thasn you sly 33 - I don't have a catch can though and have the stock airbox with k&n flat panel filter.
Cheers!
whats the torque figure...?
this still sounds weird...
  • Replies 109
I cant believe there isnt a tuner in Queensland who cant tune your car.Give it to someone who knows what they are doing and find that lost 100hp.
GTTR34,just get a T04Z and dont stuff around,lol
who needs a to4z when u can get the same power out of a 2835pro s ......
If its making the power its making the torque.
You can't have one without the other. :)
Please ignore rolling road torque figures as simple things like tyre pressure, gear ratio's, diff ratio's, tyre size/diameter and the dyno its self all make a difference.
For example....
On the dyno I run on an RB25 making 300rwkw makes around 390nm of torque, an rb30det making 300rwkw makes 540nm. Obviously the rb30 is making the power earlier in the rev range hence its higher torque, the rb30 is also running a slightly shorter diff (4.363:1 vs the rb25's 4.11:1) which again bumps torque up slightly.
But here's an interesting comparison. my rb30det when it was making 176rwkw was making the same peak torque as the rb25 makign 300rwkw, being 390nm. Obviously I made the 176rwkw rather early in the rev range in order to achieve such a torque figure.
So... essentially.. You cannot compare dyno torque figures UNLESS you have the exact same tyre size, exact same gear ratios, exact same diff ratio and both run on the exact same dyno!
The torque curve is good when tuning as you can see easily how afr's and ign. send the torque up or down at that particular rpm point.
If it makes more torque at a particular rpm running slightly rich with more ign. timing then thats obviously optimal. Leaner doesn't always mean more torque.
Looking at 254rwkw Jarrett performance dyno graph the afr's and ign. timing definitely need to be cleaned up in order to smooth out the torque curve.
Its much nicer to drive a car where the torque comes on and continues to pull rather than come on then fade off a little then rush back on.
For example....
i agree but u can help tidy up there figures for more power but torque does give u an indication of where the power is like u just pointed out with your rb25 and rb30 story....
and your right about the rb30det it comes down to the tune.. the rb30det would be great for track since it has great torque but head for head it would be shit house but it made peak power early in the rev range so there's no point reving it out... comes down to what u want it for ..
cheers
The RB30's hold power to 7000rpm+ providing you run a nice exhaust manifold, cams and turbo suitable to flow the airflow required.
You do the same to the rb30 as you would to a rb25 if you wanted the 25 holding power to 8000rpm+. As you know... a larger motors flows more air at a lower rpm.
Realistically 6-6.5k is plenty, if you require more road speed per gear its best to tweak the diff ratio than simply pushing the rpm up higher.
Remember turbo's LOVE load. :)
well if the turbo can flow yes its true it will hold in an rb30 but it has has to come to a point to make PEAK POWER......what the point of reving it to 7000rpm when peak power is made at 6500rpm thats what im saying....
When I say hold power I am talking about holding power after peak power has been made. Holding VE up at high rpm.
Stock exhaust manifold = power nosing over quickly after peak power.
A nice aftermarket manifold = power holding up for another 500-1000rpm before it begins to slowly drop off to a point where there is no point reving the motor any harder due to a lesser average power when selecting the next gear.
Its almost always beneficial to 'over rev' a motor (well the rb's anyhow) as it results in a higher average power.
Higher average power accelerates a car quicker. :D
Off topic from an off topic. :)
Yes don't worry guys the car will be getting a retune from someone different probably in Brisbane. When I first installed the turbo kit before the tune it came on a LOT harder with next to no knock.
I've run it down the quarter and after four passes I got a best of 12.89 - each run we leaned it out more and more as it's running rich as. I couldn't do any more runs as it was a competition event. Lots of wheel spin in first, sec and third, crappy 1 sec reaction time and stinking hot with track temps in the high fortys. And I'm a crap driver.
Yes it certainly is a higglty pigglty dyno curve - not very smooth but by the end of it all I'd had enough of spending money on it. It's still bloody fast - you can't do much on the street as you just go too fast.
Interestingly the tuner was making the car run leaner in some parts of the rev range and richer in others - towards the top end he leaned it out - but once on the other dyno with autronic other lambda sensor it turned out it was running very rich. I think his sensor was on the way out or something as I've had two other lambda sensors on it since and they've read the same. About 14.7 on cruise.
Cheers
    • What is the current snail?
    • Never an issue with boost control. No weird boost issues pre throttle at partial throttle like you're suggesting. It worked.   As for all the turbo damage claims, they all were started by aftermarket BOV companies. At least turbo timer companies had SOME truth about them, except people failed to realise that except for in extreme circumstances, that small amount of driving you do to park/ through pit lane etc, is enough to not have a need for a turbo timer.
    • I tell people all the time this stuff runs on a 2 MHz 8-bit MCU. The math is a bit arcane, they do a lot to get around their limited resolution and so on but it works great as-shipped. So if an 80 to 160 MHz modern 32-bit MCU can't make it work you've really screwed something up badly. Your average graphing calculator is faster these days, god forbid we start talking about what's hiding in vapes or some stupid internet-connected "smart appliance".  I suspect the lore about off-throttle surge damaging turbos must be very, very old if it was ever true. I still don't think off throttle surge is good for turbos because you're rapidly having air going in and out of the turbo on top of rapid loss in shaft speed which presumably does impart some kind of unusual load on the rotating assembly. As for the recirculating valve, I believe Nissan actually in a press slide deck of some kind explained for the RZ34 they found it improved response. Prior to that they kept the throttle cracked open instead which causes rev hang and because the throttle/engine is a substantial restriction a ton of the energy in the air stream is lost just to pumping past it. Recirculating helps reduce energy loss by bringing the intake side of the compressor up in pressure so it's not working as hard to pull air in. In DCT cars where they can slam gears I believe Porsche hangs the throttle wide open with no fuel injection to keep turbo RPMs as high as possible during the shift. As for running post-throttle boost source, I would be concerned that at partial throttle on boost you would have driveability issues. It would be constantly trying to run crazy amounts of boost before the throttle to compensate for the throttling effect. Maybe with a much more sophisticated boost control setup you could activate a solenoid that goes from a conventional 3-port setup to something that allows the wastegates to see full vacuum in that specific case?
    • Did you clean everything out? Take all intercooler piping off, empty the intercooler of oil, clean the exhaust out, etc? Intercoolers make great catch cans... Which makes them less useful for intercooling... But very worth cleaning out, along with all adjoining piping.
    • Update Got turbo back from hypergear, installed everything etc. Bled coolant, wasn't smoking so I thought beauty she's sorted now. Went on a drive, car up to temp, let it idle for about 15 seconds, gave it some gas...nice puff of smoke again. Fml No doubt my turbo was pretty worn anyway but nonetheless frustrating that the problem persists.
