Hi.
I have an r32 and I am in the middle of installing an el apexi mechanical boost gauge. I have followed one of the tutorials, but it fails to detail a few things. I am ready to connect the boost hose to the engine hose with a t-piece shown in the picture but....
Question is, with the boost hose 4mm big- thats parts figured out, how big do the inlets have to be which feed into the hose shown in the picture. I wanted to eliminate guess work and know which t-peice size I needed to buy before cutting.
thanks
https://www.sau.com.au/forums/topic/95920-mechanical-boost-gauge-install/
what type of hose was supplied with the apexi guage?
is it the hard clear plastic? like an autometer one?
if it is the std size hose will fit over the end of it .. then cable tie it,, then plug it into the t peice... they should all use the same size hose.
The apexi hose is the soft rubbery one and the t-peice, (which has all inlets 4mm big) came with the package and fits with it. However the engine hose shown in the pick is smaller. Is it safe to stretch the hose over the 4mm t-peice.
if it it smaller... go to a good shop that has silicon hose... you know the fancy blue stuff ... cos that stuff is new and and will definatley stretch over the bigger T piece better than the black rubber hose.
usuall like $16 a metre .. but you wont need much
I'm having problems with that hose at the moment in my R33. I've got an EL series Apexi mechanical boost guage as well and was also looking for options on plumbing it into this line. I've taken it off the bit where it joins on to the back of the plenum to get a look at it, and now it keeps on splitting when ever I put it back on and drive around normally for about a week or so. Time to get some new tubing me thinks.
"There's very little meat in these gym mats!"
It's 3mm vacuum/boost line.
The factory one likes to split after you remove it. You can get 3-4mm tee's from supercheap. If they don't have the exact tee you need you can also get 3-4mm adapters.
There's no need to change the hose. Just but a smaller T-piece that can fit nicely onto the engine hose. Then slip the larger apexi hose onto the smaller t-piece and secure it with a zip tie. I had this problem myself as the stock hose kept on splitting on the huge Apexi supplied T-Piece. Make sure you zip tie all three t-piece connections.
I had the same issue with fitting a Speco boost guage - the hose from the guage was a larger ID than the stock hose that you cut and fit the T-piece into.
I found a T-piece at Autopro that had 1x4mm barb and 2 smaller barbs.
Fitted perfectly.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
