Dyno Day
proengines
 Share
  • Replies 80
well, i was happy enough with 174.8 rwkw, let alone 272 with an exhaust leak!!! :D
however, im only running a fmic, an exhaust with a std cat and stock boost!!! me thinks there is some un-tapped potential there......
Edited by Frink
Not sure.. I *think* it's the engine originally in the Trueno. The engine it's replaced with in D is from the AE111 and that's the one that revs to 11k. Either way, my bro is clueless about the whole thing, just like Takumi hahahahaha
The engine to start with is a 4AGE and is replaced with another 4AGE. You can actually buy the engine they used in the cartoon, it was used in a racing series called Formula Atlantic.
What i can remember:
96 R33 GTS-T S2 with 3" exhaust from dump = 151kW
91 Corolla Seca SX, stock = 75kW
Pro Engines work ute - 137.3rwKw!
Googies - 272kw
Frink - 174.8 rwkw
The litle datto 1600 -180sumtin kw
Corvette - 275kw
Mine - 290kw
Other grey gtr was 260somthing i think??
But thats all i can rember/pull from this thread..
i want one...
Formula Atlantic Facts.
1.6-liter, four-cylinder, non-turbocharged, 16-valve, fuel-injected, dual-overhead cam, Toyota 4A-GE engines, capable of producing 240 horsepower at 9,500 rpm and speeds in excess of 165 mph
The teams run a 12 race season on a minimum of $650,000usd
http://www.toyotaatlantic.com/Atlantic101/FastFacts.asp - interesting read
Thanks for remembering my power figure geordie.....
I was impressed when mine made 186.7rwkw running standard boost :D
AND, my power FC is sitting in my bedroom waiting till very early next year to go in and then ill guarantee over 200 at the wheels...
Hows that for an R31??? :)
 Share
    • Hi fellow SAU members, I want to put coupe tail lights on my R32 sedan. I have been told it was as easy as changing the boot lid and the tail lights and possibly the rear bar. I have since found out that this is incorrect after buying the lights and boot. The coupe boot dosnt allow the boot to oprn on a sedan and the tail lights won't fit either. Has anyone done this or seen it done and could help me out with some guidance or instructions to get it done.
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
