hey Darren. the bosch pump has worked great for me so far. i know Nightcrawler has had some problems with the 040, though. then again i have heard bad things about the walbro aswell. do a search in 'forced induction performance' too, there are quite a few fuel-pump threads that mention these two pumps. :P
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1738637
Darren,
I have had a bosch o40 or 044( cant remember) for many years now ( in fact martin d did an artical in hpi on how to do a in tank fit using our car as guinea pig for fit / photo's_at tilbrook's ).These are quite good pumps, we have had no trouble however they are on the noisy side with no music pumin!
Regards,
SKYLINE (Kym)... B)
Edited by skyline
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1738783
Cheers guys just read the forced induction section and it seems they are quite similar in performance whilst the Walbro is some $60 cheaper and the bosch 040 can have some issues with fittment(eg the 1/4 tank which could cause surging issues). Cheers Kym might have to find that HPI Mag as i will be doing it DIY styles.
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1738816
hey, the "1/4 tank" problem with the 040 is due to incorrect fitting of the pump in the first place, nothing to do with the pump itself.
sydneykid is not a fan of walbro pumps (which is enough for me, to be honest) and another guy i spoke to who has an escort race car said "nothing but bosch". you should be able to pick up an 040 for about $220-230 or less.
how much power are you planning on making? the 040 will be fine up a point but you might need something bigger. but then don't go for overkill or you get noise and overheated fuel (depending on your setup)...
cheers
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1738929
Yeh the 040's are about $235 delivered where as Walbro are $175 delivered, yeh i was originally more keener on the 040 after hearing about issues with the Walbro, but now they seem to be quite similar, Thinking i might have to spend the extra cash and get the better quality one(040).
After AFM and a FC retune should be up around the 210-220kw mark which i will be happy with for a while.
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1738953
i got my 040 from Greddy in the Trader section for 230 delivered, came all the way from great brittan.
i heard about that surging problem, on the bottom of the 040 there seems to be no nozle to connect that pick up hose thingy?? as all the other pumps habve them that maybe be the problem. i DUNNO really. :)
havent fitted it yet coz im a slack bastard :D
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1739312
I took out my Bosch 040 that was noisy as hell (especially when you have below 1/4 tank or the weather is over 30 degrees) and put in a Walbro 255lph. Have had the car dynoed with both pumps and power is the same, at the same fuel rail pressure. I had the Walbro rechecked just the other week, after hearing disparaging comments from some SAU users, but Turbo Tune said the pump gave 'more than enough' fuel pressure for 200rwkw through 4 x 550cc injectors. They could not fault the pump whatsoever, yet I did have a 4 month old Bosch 040 fail year back.
Edit: Like DriftR says, the oem style mesh pickup of the Walbro is far more reassuring than the Bosch pump setup - the Bosch has no filtering and the pickup is not as low down (which could explain people's surging problems).
Edited by Nightcrawler
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1739315
Having an 040 installed right at the moment (with z32 afm, fpr, fuel lines, sitc, direct battery feed to fuel pump, etc yadayadayada), and retuned on the safc.
Hopefully pick it up tonight...
Yah, have read that Walbro isnt that great but is serviceable, big thing there is the amount of cheap chinese copy Walbro pumps that are out there. Nasty stuff apparently. Read a lot about that. But also read genuine items flow like a 040.
With the 040, you must install it as low down in the tank as possible, to get around that 1/4tank surge 'feature'. Due to the pump not having a 'sock' like the 918-series. Install low down with a custom bracket, and that wont be a problem.
I got my Bosch 040 off ebay (victoria, fordefi) for $198 delivered, with 12month warranty.
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1739943
I got my 044 installe din the 32 by Shaun. Cant hear it at all, excpet on hot days it gets a little noisy.
Id expect them to say something like that regarding a skyline :)
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1745863
I needed to get a new fuel pump after I did a SR20DET conversion in my Silvia, and went for the Bosch 040. It makes a buzzing noise every 5 seconds or so on idle usually, but can't usually hear it much when driving normally. As others have said though, it's almost constant noise when you are low on fuel. Doesn't bother me, I just don't pay attention to it.
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1745866
same with mine too. shaun installed it, and it never makes a sound. except yesterday when the weather was warmer than usual, i could hear it.. why is that?
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1746228
When the weather is warmer your fuel is warmer. When the fuel is warm it expands. When the fuel is warm/expanded the pump has to work harder to pump the same volume of fuel, compared to a cold day when the fuel is more dense. The pump working harder is the noise you hear.
When I had my 040, on any day when my car had been out in the sun for a while and the temp was over 30 degrees, the buzzing noise was horrible.
https://www.sau.com.au/forums/topic/96012-fuel-pumps/#findComment-1746259
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
