  • Replies 92
Posted Images
Well Ill try the ghetto boost mod to ensure the wastegate isnt creeping open (drill out the holes slightly).
3000rpm is pretty damn good to have full boost!!!
It looks like Im getting about 9psi by 3800rpm in 2nd.
Running a bit rich and probably not optimum ignition timing so maybe I could get thatdown to 3500rpm..
Edited by benl1981
no, you don't drill out the holes.
I got a cutting torch and spot heated a bit of the actuator and bent it one way about 45 degrees, then spot heated another bit along the rod and bent it back the other way..... then bent another bit back..... Kinda like the ASCII 'art' below....
.........__
PS. Ignore the . look only at the lines... :O
Edited by Bass Junky
you can drill NEW holes in the end of the rod that attaches to the flapper. I actually tried that......
But boost was, hmmmm, how to I put it....... VIOLENT! :O
Boost was miles to quick to come on and the EBC couldn't regulate it.
so I changed back to a more moderate ghetto mod :(
IMO i would go and get yourself a decent EBC,for piece of mind,
Bass full boost at 3k is bloody good.I have poncams and still full boost isnt untill 3800rpm.
Mine is a Precision BB highflow,shafts and wheels not balanced inhouse like GCGs but the cartridge(wheels and shaft) are sourced from Garrett already balanced.That is the only difference that i can see.
Cranked boost up to about 13 or 14psi. Can get that boost by about 3800rpm in 3rd. 2nd is about 4100rpm.
Not reving it past about 5000rpm but boy does it feel like a shove back in your seat as it comes onto the higher boost.
Cant imagine what 18psi +tune will be like. Currently running very rich.
You do have to get into the accelerator a bit more though with this turbo to make things happen
Edited by benl1981
Forget about the lag - It's not really an issue - I think Im running about 13-14psi. I can't believe the hit it gets
Be careful if there is any wetness on the road. These cars are monsters. 3rd gear.. 3000rpm boost building. about 3800rpm steps sideways as it hits builds to 14psi!!
Not going to push it anymore till injectors then tune. Seriously though anymore than 240rwkw for the road is just plain silly :P !! Whatever its making now running as rich as buggery is plenty
Well I guess the 170rwkw it was making before at 10psi on stock turbo was plenty also hahaha
Edited by benl1981
Increase grip. :P:D
I also have a vg30 turbo with r33 hi-flow front..Dont know much about it but it made 235rwkw at 10-12psi.
Ive recently converted the car to manual and taking it back to get retuned..
This turbo comes on really aggresive i love the feel and shove it gets, cant campare it to the stock turbo. Midrange couldnt really be tuned as Im only using a safc.
theres some old threads about this combination of turbos if yous arn't aware, that person had great results also.
Cheers
Hi Sloutch,
Here is the link I was refering to, good read.
http://www.skylinesaustralia.com/forums/t22706.html
I was extremely interested in the thread as I have an unknown turbo on my car and its seems to be a similar one in the above thread.
Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
