  • Replies 92
Posted Images
Turk,
Most likely a dump pipe design issue.
yeah dont know man, been given all sorts of reasons like the flow is too good hence the spike
and was advised to add octane boost to stop pinging
could be cams
hasnt been a simple upgrade solution like i was informed in the begining, bolt off bolt on 50rwkw good story
I should have gone for the HKS GTRS option would have cost me roughly the same after havein all the problems with the highflow
R33GOD
Why limit yourself because of a faulty product?
Not saying that Slide turbos are bad/faulty, as i have had good experiences with Aaron (Slide). Sometimes shit happens and one or two go bad; i know i am in the technology trade. But when you get the replacement unit, don't hold back, it should be good to at least 16-18psi, if it fails then ask for a refund.
I know that my high-flow turbo ran out of puff at anything over 16psi (ie: the increase in rwkw did not justify the increase in boost). And with my level of head work, the turbo was limited to 270rwkw. On a std head, i would not expect to see over a genuine 250'ish rwkw.
i dont know why but i just get put off. i just dont want it to break again. being bush bearing and all.
i just cant afford having my car off the road again. so il drop the boost to keep it safer
Just realised i started this thread in Nov '05.
Back then i stated; "Hopefully this set-up will last approx 12 months, then the bottom end will be treated to forgies....". It actually lasted 16 months and dropped compression in cyl #3 at a Calder Park track meet :nyaanyaa:
Now i'm doing a whole lot more than just forgies :ph34r:.
Funny how your words come back to haunt you.
So i'll state: Hopefully the new setup will last 30 faultless, hassle free, years :worship:
Numerous track, motorkhana, drag and cruise days, 7yrs of hard driving. A fair bit of punishment and high temp/stress events.
Honestly; when the piston was removed we barely found the fault. 4 hairline cracks between the ring lands, that's it. No melting, detonation, missing bits, etc. Bores, bearings, rods, crank, etc were still in perfect condition and the head of the damaged piston was unmarked. So the conclusion was fatigue.
here is my recent dyno, (keeping with the topic) ive just had a rb25 highflow with the vg30 exhaust housing, also a nismo fuel reg and z32 afm.
Edited by Sambo33
wow, thats not too bad! :)
mine did all 6 ringlands :D
See that's were i am a little disappointed: i farked up an engine but have nothing to show for it, i have no bragging rights!
You stating "mine did ALL 6 ringlands" has a bit of cred; or better yet "kicked a leg out of bed".
I can't even fark up an engine properly :(. Funny thing is, on 5.5 cyl the car still felt strong, Driving home, after the race, i gave it a squirt in 2nd gear (to 100km/h) and thought all was good, and the oil out the filter was just massive blow-by. The next morning, when it took almost ten minutes and endless cranks to start, was my first indication something was wrong. Compression went something like: 158, 160, 83, 161,159,160. Yet when the power came on, i had no smoke and the car almost felt as strong as usual.
Barely justifies a $15K conversion/build :laugh:
lol, i see your point, better to kill it good than something small requiring a rebuild. its fairly disheartening at the time, but in the end its good to know you now have an engine that can cope with the extra kw :D
it is funny too, when my compression was down the car still pulled hard and felt like nothing was wrong.. execpt for the oil cloud blocking my rear view and filling up my 1L catch can in one good 4th gear boost :laugh:
Edited by Sambo33
wow. thats the second one that ive heard of to go in the same way. what a suprise. whos one is next, do you think?
lol probably mine; its now officially been one year since I received it and installed it.
out of warranty FTL
but still, a warranty on a turbo is a good deal for sure
Al i take it your not using another hi-flow with that 15k build..
What build route did you go?
Its still good to see that these little hi-flows last a while, Im acutally holding back on chucking on the gt30 because of the hi-flows potential..
Just a run down..I made 235rwkw on 10-12psi with exhaust,fmic,rb20 actuator and SAFC..thats about it without getting to technical.
As mentioned earlier, i dumped sold the Hi-flow for a HKS GTRS, only to find (at a later date) that my exhaust was the main reason for the lag. But that hi-flow is now in a friend's R34 GTT, and it's still going strong, making 270rwkw@15psi.
The build is very extensive as it's being prep'ed for motorkhana and track work
The key parts:
- rb30det conversion (built to rev to 8000rpm)
- GReddy plenum
- Tuned length, high mount, ext manifold
- Garrett GT3076R (GT30R) [smallest turbo recommended for the engine]
The end result should be about 300-330rwkw@20psi, with better response than a hi-flow turbo :P
Turk,
Is the dump pipe a split dump design...i.e . seperate pipe for wastegate.
I have a split dump design on the 33 with the hi-flow and it seems to work a treat. It plumbs back in at the bottom of the dump where it bends to go to the cat.
The key parts:
- GReddy plenum
The end result should be about 300-330rwkw@20psi, with better response than a hi-flow turbo :)
yeh Al i did see that post earlier, its great to see the turbo still going strong and at a very respectiful power figure still.
Your build sounds awesome, good luck with traction. Though it sounds like the turbo will be very progressive and im sure you have concentrated on the suspension..so good luck with it all.
Cheers
thanks :glare:
Turk,
Turk,
Is there certain brand for this dump pipe I heard the Just Jap one is shite it apparently doesn't fit right
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
