Why not grab a 3inch single stainless dump pipe off ebay? I got one off JustJap for around $200 delivered. Top quality, fitted to my Stagea (R33-based) without too much worry.
Or spend the extra $100 and get the long length split dump from Batmbl, in mild steel.
I would think a 2.5inch might be restrictive when you (eventually) go chasing higher kw gains........
https://www.sau.com.au/forums/topic/96104-split-dump-pipe/#findComment-1740608
to be beneficial they need to split for approx 30cms. that being said batmbl (under business trader section) sells a split dump 3" and front pipe in one unit for around $300 ish i think and its a all in one piece that should do wonders if you have stock dump and front pipe setup
https://www.sau.com.au/forums/topic/96104-split-dump-pipe/#findComment-1740625
Hey guys, i just got back from my local exhaust shop and im having the same issue, wether to get a 1 piece 3" dump or split dump which begins as 2 1/2" then to 3"?? would there be any power gain advantages with the split? cause i heard they reduce tubulance when the waste-gate opens up.. what you guys reckon?? Here are some pics to give you an idea..
1 Piece Dump
Split Dump
https://www.sau.com.au/forums/topic/96104-split-dump-pipe/#findComment-1741358
I'm using the CES split dump/front pipe (great quality btw)...
while i haven't compared the difference between the split and a standard 1 piece pipe, i can tell you that the difference between a split and stock pipes was HUGE. Boost comes on earlier and stronger.
Can also notice a difference when comparing against a couple of others with same mods but just 1 piece dump/front pipe (although this is just by my seat-of-my-pants guage)
like arkon, i believe the theory to be quite sound and that's what initially drew me to the split dump/front...
https://www.sau.com.au/forums/topic/96104-split-dump-pipe/#findComment-1742702
i disagree... i have a genuine HKS split dump (which is not split for 30cm) and a 3" blitz front pipe and the difference the made was huge...
at the end of the day though, the standard dump pipe is a p.o.s... and any of the aftermarket dump / front pipes will benefit your car...
oh yeah if you are changing the dump / front pipe a high flow cat is a must imho...
https://www.sau.com.au/forums/topic/96104-split-dump-pipe/#findComment-1743573
I got my split dump put in just a few days ago, car seems to have a much deeper/meaner sounding grunt, however does feel alot more sluggish when coming onto boost, almost regretting getting it put in atm, im just hoping ill see a bit of a benefit in the higher rev ranges - havnt actually experimented too much with this due to the hot weather.
https://www.sau.com.au/forums/topic/96104-split-dump-pipe/#findComment-1744345
i remember there was a guy at the ice dyno day a few weeks ago,
he just had the normal mods intercooler/exhust..
he nearly made the same as the cars with the pfcs :P
I thought they wouldnt be so good, but after speaking to him and seeing his result i wana get me one 2
https://www.sau.com.au/forums/topic/96104-split-dump-pipe/#findComment-1744660
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
