Can Someone please direct me as to which section i need in the ADR rules for pod filters and Intercoolers?
I was defected for my pod last friday, although it is in a box. the cop also sent me a traffic infringement notice today for driving vehicle non standard. at the time i was defected he told me anything non standard is illegal including using non factory type tyres. obviously i knew this was b/s so contacted my solicitor straight after.
anyway please help this is already going to court!
This is the pod box.. the cop said it was as much of a defect as the pod itself as it was non standard.
Edited by MintR33
https://www.sau.com.au/forums/topic/96115-need-adr-rules-apap-please-help/
AFAIA the ADR's don't specifically cover pod filters or intercoolers, they are actually EPA issues to do with intake modifications effecting emissions. According to VicRoads, at least, pod filters are not an 'engineering issue.....refer the EPA'.
Suggest you contact engineers (not the desk drone) at your local rego authority (wherever you are) as well as the EPA.
The only way I see you can win your case is if you provide proof you have not exceeded emissions levels set by the ADR's your car is complied to. The reason is, you have modified the standard emissions system which is proven by the manufacturer to pass relevent emissions standards.
Seeing as this is an expensive test that you will have to incur the cost of, and pod filters are widely regarded not to offer significant power gains, I would just remove it.
The first page of a google search will show you the emissions composition for the relevant ADR standards here:
www.npi.gov.au/handbooks/aedmanuals/pubs/motorvehicles.pdf
Edited by drunkenmaster
I agree, cops usually enforce RTA regulations and not ADRs. Ask to speak to the engineers at RTA and they should set you straight about what's what. Keep a level head and they are usually easy to get along with. An infringement for non standard? Was it specific? Just about every car on the road is non standard in one way or another, try to find out the parameters they use to determine this. And WRITE DOWN EVERYTHING THAT YOU ARE TOLD BEING CAREFUL TO NOTE NAMES AND TIMES. Another source is tech help at the NRMA believe it or not, you'd be surprised at what these guys know.
Good luck
paul its a small town with a few cops (leeton, nsw)
he does have 2 live there n the cop will keep hounding him. if he gets the law on his side he can then write down times that he gets pulled over etc from this cop and put an harassment order on him. this makes the police in his town stay away from him for 6 months unless it is warranted. this has happened b4 to one of my mates who lives in vic.
Yes, thats pretty much the reason for it. this is by no means the first time i have been targetted for doing nothing more than driving a skyline in a place where V8's are the dominate species.
I'm sick of letting it slide because all that is happening now is they are taking advantage of me, thinking i am just going to give in each time.
Small town, and them pulling out the ADR one...
Out of interest, did you sleep with this said policemans daughter and get caught recently?
I think you will find he's pretty much spot on with the ADR thing. But you must have done something to really annoy them to pull that one on you.
I thought the air pod was more of an EPA noise issue than an EPA emissions issue.
Atleast that's what my engineer said - something about cops pulling bullshit about pods because it's linked to noise, but he also said the noise and pod logic only really applies to rotories because they are very loud through pods.
Either way good luck good on ya for goin to court.
first thing. is it engineered?
the reason pods are ilegal is. they dont offer the same flame traping properties as a sealed air box. and noise emissions i think.
(yes its not like a backfire is going to go all the way down 2 or so metres of plumbing and a turbo!)
to make it legal it has to be "out of site"that is what my engineere said for him to engineer it.
i think you may of got bent over by an ignorent cop.(there are plenty)
it usaly helps if you put your mechanics licence next to your licence in your wallet so they see it. no more gay defects after i did that!!
by the sounds of it you need to be armed with a enginereres cirt folder.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
