Thanx thats what I had thought from what I have been reading on here, will they be a bit laggier or much if a muchness if tuned right (assuming you may have done this at some time so might know), a bit new to TURBO cars so not so sure I suspect tuned right they may even help eliminate some lag due to better/more flow cylinder filling etc. Is that a possibility or have I missed the mark completely :P
They are not laggy at all. They reduce lag over the factory cams significantly and increase power everywhere.
I use the poncams on my daily driven setup, with a T04Z running 23 psi of boost and 1000cc squirters. the poncams are 260 dur and 9.15 mm lift. using tomei lifters and jun valvesprings. manley custom Gen II 0.5mm oversize valves and ratainers. when i didnt dail in my cams, the car was sluggish to come onto boost, but after expert advice by SK the cams were dailed in and i was actually amazed at how much it allowed me to push the ignition. the car came to full song 400rpm earlier and acually from a roling start it would light up all 4rs through the 1st, 2nd and it would chirp the 3rd. the cams made big big differance, the power increased to 467awkw. on the drag engine im building atm i will be eploying 1mm oversize valves, and jun 280 deg 11.35mm lift cams, to push the T51 SPL BB turbo. all the bits in the head will be jun exept the valves. for the street i dont recomend bigger then 260 on both in and ex.
Thanks mate that confirms what I had suspected, cams I ordered wont make it to me before the dyno time I have booked so will be able to post good before and after cam type dyno sheets for all to see.
Would have liked to put em straight in though with all the other bolt-ons and powerfc but just isnt going to happen. :glare:
why do people not reccomend 272/280 cams for the street? i have them and they dont cause any drivability issues at all so whats the downside besides maybe abit of lag, but plenty of top end power?
Fuel ecomomy
Emmissions, nasty
Noise, a legal 92 db with 248's is not going to be legal wiht 272's
Soft idle problem (and just up from idle) with air con, electrical and power steering loads
Plug fouling
Clutch wear, in fact the full drive train, as you have to use higher rpm to get up the torque curve
Extra capacity does overcome some of those, for example an RB20 is really weak with 272/280‘s but an RB30 with the same cams is strong at idle and just above. High (static) compression ratio also helps as the extra overlap lowers the (dynamic) compression ratio anyway.
:huh: cheers :laugh:
they do look like an interesting bolt on don't they and to run the cams surgested would make one nasty rb26 ;)
far out im diggin from the past but those tomei turbs are big, bigger than the T618Z's ive used in the past... even the T618Z's needed big big cams to work effectively... like 280 big and as far as lift goes they were big enough to require relieving the cam tunnels (common i know but still)
anyone used them? they are bigger than TD06's but low mounted.
Hi I'm looking at purchasing the JUN stage one camshaft kit from greenline.jp , (272/272 9.7mm lift) the kit says it includes valve springs, is this all that I need to fit the camshafts??
No retainers etc needed?
Cheers :P
does anyone know the standard r33 rb26dett cam lift and duration
cheers
from my R32 GTR manual
Intake:
valve opens 7deg BTDC, closes 53deg BBDC
Exhaust:
valve opens 63deg BBDC, closes 7deg BTDC
does that make sense?
lift is not stated, just clearances
Edited by ronnydotk
Intake:
Exhaust:
Thats good I can work the rest out thanks but maybe the inlet closes 53deg ABDC ??? making it 240 duration against 236 for the exhaust dunno.
Edited by ike
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
