Sony is still tossing over the blu-ray players being built in.
PS3 for me regardless.
CPU
Cell Processor
PowerPC-base Core @3.2GHz
1 VMX vector unit per core
512KB L2 cache
7 x SPE @3.2GHz
7 x 128b 128 SIMD GPRs
7 x 256KB SRAM for SPE
* 1 of 8 SPEs reserved for redundancy
total floating point performance: 218 GFLOPS
GPU
RSX @550MHz
1.8 TFLOPS floating point performance
Full HD (up to 1080p) x 2 channels
Multi-way programmable parallel floating point shader pipelines
Sound
Dolby 5.1ch, DTS, LPCM, etc. (Cell- base processing)
Memory
256MB XDR Main RAM @3.2GHz 256MB GDDR3 VRAM @700MHz
System Bandwidth
Main RAM 25.6GB/s
VRAM 22.4GB/s
RSX 20GB/s (write) + 15GB/s (read)
SB< 2.5GB/s (write) + 2.5GB/s (read)
System Floating Point Performance
2 TFLOPS
Storage
Detachable 2.5" HDD slot x 1
I/O
USB Front x 4, Rear x 2 (USB2.0)
Memory Stick standard/Duo, PRO x 1
SD standard/mini x 1
CompactFlash (Type I, II) x 1
Communication
Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T) x 3 (input x 1 + output x 2)
Wi-Fi IEEE 802.11 b/g
Bluetooth 2.0 (EDR)
Controller
Bluetooth (up to 7)
USB 2.0 (wired)
Wi-Fi (PSP)
Network (over IP)
AV Output
Screen size: 480i, 480p, 720p, 1080i, 1080p
HDMI: HDMI out x 2
Analog: AV MULTI OUT x 1
Digital audio: DIGITAL OUT (OPTICAL) x 1
Disc Media
CD PlayStation CD-ROM, PlayStation 2 CD-ROM, CD-DA, CD-DA (ROM), CD-R, CD-RW, SACD, SACD Hybrid (CD layer), SACD HD, DualDisc, DualDisc (audio side), DualDisc (DVD side)
DVD: PlayStation 2 DVD-ROM, PlayStation 3 DVD-ROM, DVD-Video, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW
Blu-ray Disc: PlayStation 3 BD-ROM, BD-Video, BD-ROM, BD-R, BD-RE
lol dude first off the systems are very close in terms of graphics and performance.
Gezz I don't know what you call 'close' because the PS3 is twice as powerful in system specs. And at this level of technology, that's a fair bloody jump.
but I like underdogs and the PS3 is an underdog in the console playing field  B)
Underdog :| Microsoft is still in deficit with their XBOX, they sell the console at a loss just trying to get into the heavily dominated Playstation gaming market. They're yet to make $1 profit. They expect to finally start making a profit with the 360, 'expect'. Playstation has always had the pole position vs xbox & with the new PS3 console being twice as powerful as the 360 & better games, I think Sony will continue to lead the way. Underdog? I think you’ve got PS3 confused with infact XBOX.
Ps3 is not twice as powerful as Xbox 360 because it doesn’t even exist yet.
You actually believe anything Sony has to say about a console that hasn’t even been made yet?
If Sony can make you believe all this about something that doesn’t even exist yet then they have a licence to print money and we might as well all buy shares in their company.
Last time I checked we were all gamers, not some Microsoft or Sony fan club.
Xbox 360 will be out a full year or so before ps3 in Australia, if you can afford one, and like playing games why the hell wouldn’t you buy one?
If ps3 comes out and is great and has good games and you can afford to, why the hell wouldn’t you buy one?
End of story.
farcry for pc is kinda old now im sure if they wanted to remake it for pc they could use the best possible graphics and it would dominate the xbox.
when have you ever seen water like that in any pc game?
You cant really compare consoles and pc's, they provide vastly different functions.
Thats why people with pc's still buy consoles.
The only reason I attempted to compare them was because of the post a few above made a statement that really doesnt hold much truth to it. I have no doubt in a few years pc's will be vastly superior to xbox 360 and ps3 but at the moment I dont know anyone who has a better pc system then an xbox 360.
I know you dont menco.
To build one you would have to spend about 10 times the cost of an xbox 360. Who would bother when you can just get a console and sit around on your leather couches with your mates and play some widescreen action?
Edited by noise
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
