well when eva i play music, the doors vibrate soo much, like even when the music isnt loud. i dont have subs at all.. is there sum way to stop the vibrations or at least make it alot less? cause its driving me mad lol...
https://www.sau.com.au/forums/topic/96127-door-vibrations-when-playing-music/
i have the same prob, but only with my left speaker, i found when the left window is up it stops the vibration slighty, and now when i been working on my car puttin the new system in, the speaker was actually loose from the pod
hope this helps slighty
turn the music DOWN
new some one would say that, lol.. it happens all the time even when the music isnt loud, like there is alot of rattling. ive taken the doors apart many times to try and find anything loose but havnt been able to. i put bits of foam tape around on some areas to try and stop vibrations but didnt help much.
Use sound deadening.
If you wanna checkout some pics hit cefiroz.com it's the first article there.
how much does that stuff cost per door?
There are a lot of different brands and types of sound deadening product available. Over here one of the cheapest and most value for money is a bitumen based product made by Bostik. It's about $100 for 10 500mmX500mm tiles. You heat em up to make em soft and flexible them stick to the inside of your panel as there is a peel away sticky side.
Go ask your local panel beater or hardware store if they have anything similar.
This can make a hell of an improvement.
Also check wires and lock/switch cables aren't rattling, zip tie and cover with sponge/foam to prevent rattling.
When I took my door-trims off, I banged on the door and listened for rattles. Half of it was from the door trim itself! Up and under the inside of the trim, where it sits on the window-sill, there are metal sort of hangers/reinforcements.
I had some strips of velcro spare, so I used the furry side, and cut them to length. Now it sits tighter, and hasn't made single sound!
Also, tighten the door-skin... speakers don't need much volume to make that stuff shake, and it sounds like there are shopping bags in the door if they're loose.
ah so its them damn metal hooks! i keep looking at them and think, narrr couldnt be them making all the noise, and then put the foam tape next to them :)
oh and by door skin, u mean the plastic thats stuck in there to stop the water from affecting the door trim, ay?
Nice one, RocketBoy!
Ethan, yeah, that's it! The crappy glue stuff on them has a lot of give, and the door-pods are ported at the rear. All the bass travels through the door, then tries to push the plastic door skin around. It just sits there flapping.
Glad to hear the tape on the metal hooks worked for you! Seems it's not just me, but a common problem that people are experiencing.
just put velcro (the furry side) on the metal hooks and its reduced the vibrations alot.. it doesnt sound like it about to shake apart anymore :angry: .. although there is still vibrations from the rest of the door (dont have sound deadening yet), there not as noticeable.
thanx heaps guys!
Yep, thats pretty much what I did with mine. The R33 have a large access hole that you can utilise to get your arms in and apply SD to the outer door skin (inside of outer door panel), this stop a lot of the large flat surface metal from resonating and help produce clearer and crisper notes in the mid/mid bass region.
I also cover my access hole with 6mm MDF then SD'ed over that when doing the inner skin.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
