Which car looks hot?
121 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  ZERO said:
Well the general idea was to show which car is Hotter specifically with these two cars..
Well I clicked on S14a on the survey coz in general I like them more, but I think of those two specifically I like the R33 more, so subract one vote from S14a and add one vote for R33.
  Quote
its quite amusing. this is also on the ns.com forum and it is biased towards the silvia. and on here it is towards the R33. funny that....................
Yeah, strange that a Skyline forum members would like a Skyline, where as a Silvia forum member would like a Silvia! That is just bizzare!!! Who'd of thunk it?!?!?!?!?! :lol:
  • Replies 48
They're both ugly.
EDIT: Well, not so much "ugly" as "bland". I frequently mistake the R33 for a Magna, and everything but the nose of the S14 is so ho-hum that you could use it to cure insomnia.
Edited by scathing
That R33 looks very average to me, the S14a shits all over it.
Terrible offset on those R33 rims, look how much they sit in the gaurds. Stock rims would almost look better. Needs a set of spacers on their badly...
Id say the Blue R33... since i bought it off you two weeks ago lol. Cheers for blacking out the plates. Cars running great, found a large allen key stuck underneath the bonnet hinge for some reason though.
I think S14s look too much like family cars
hey man, can i ask where you're from?
i saw a S2 R33 the other day in my area in that exact color, but didnt remember seeing a CF bonnet....
Nah mate im in Newcastle, up from Sydney. Mines a series one though
I got confused with the R33 with a magna when i first got into skylines, and yes the R33 looks very boring, but damn, i would rather have a boring looking car than a fulgy looking car. however the angry eyes is the only thing the 200's got going looks wise.
R33 rear + S14 front = :(
s14 a
ive had 2 silvias (s13 and s15) and 2 skylines (r33 and 34)
id rate the 14 over the 33 , but not the 34
its not imported for cheaper insurance and parts , sr20 is the most popular engine in terms of performance parts , its light and easy to extract power and speed .
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
