I was at the place where i get my car scerviced today and there was a kid there with his silvia on the dyno.
I got to talking to him as he was tuning his car and i was curious as to what he was doing.
He was doing a power run, looking at the AFR's and then putting a resistor between the AFM and the ECU!!!! he would do another power run and check the AFR's.
I informed him this would lean out the AFR's right accross the range and he looked at me like i was an idiot!! and said to me Look at the afr's man, its rich right accross the range, sure enough he was right!!!
He was upping the resistance value each run by 0.02 of a watt.
I saw the figures, before and after, and he went from 152rwkw to 164rwkw and his afrs were still below 12:1
He said by doing this he had illiminated boost cut, advanced the timing, and was using less fuel.
Not bad for 6cents for the resistor...
why is it stupid if done monitoring the AFR's?
it is doing the exact same thing as a safc except right accross the rev range. and providing you don't go too lean what the hell is wrong with it?
I think in the right application it is fine.
I mean, if worst comes to worst hes only going to blow up a CA or even better an SR. Good for him!
At least he is smart enough to test it, not just read something on the net saying use a xx resitor, it will help.
I wouldn't use a pot, apart from getting the right value, as there's vibration, moisture issues etc...
Once you have the right value, measure the resistance, then put in a fixed resistor - You don't want your afr's changing at every pothole, of it it rains :-D
yeah thats what i was thinking about a pot. as soon as you bump it you lean out.
CA's have feelings too! just because they are a bit "special"!!! there seems to be no love for the CA anymore:(
Its just as dodgy as bleed valve boost control. Plenty of people use that without concern.
Both too dodgy in my opinion, but those using bleed valves for boost or fuel cut defender are just as bad. He is loosing flow of electricity instead of air.
[qoute] Its just as dodgy as bleed valve boost control. Plenty of people use that without concern.
Both too dodgy in my opinion, but those using bleed valves for boost or fuel cut defender are just as bad. He is loosing flow of electricity instead of air. [qoute]
haha! that means I am a bad man... I have a turbotech bleed valve, I am a very bad man...
BMW's group A cars back in the 80's were tuned using the same method, it worked well for them.
Thats very interesting. I used to love those John Player Special little black BM's:)
Edited by CEF11E
*sigh* i love these types of un-educated comments.
How can you even remotely say that?
I was running a bleeder of my gate upto 24psi... 7psi through the valve and a hold in the line for a bit more
It never spiked, never changed the level of boost, never gave a reason for me to think i'd wasted $10
Correctly done a bleeder can be of the same level as an EBC without the mammoth expense.
I'll point out what i see as an issue with this idea.
he is adjusting the AFM reading accross everything. It is not dependant on RPM / Load / Temp / Conditions.
Sure he is testing on the dyno I assume full power runs at full throttle.
I would say he could get that quite right.
I doubt he tested all rpm / load conditions at all temps.
If he leans it out with this method, everything is leaner !!
Things like close loop driving will be leaner. Light throtle leaner. Cold start leaner etc etc ....
Sure he can leave a "buffer" but as you can imagine it would not be an ideal way to do things.
Closed loop wont be leaner. It will adjust fueling based on 02 sensor output!!
It's dodgy but hey if you dont go too far it should be ok. I mean you wouldnt do it to an expensive engine..
for the cost of a jaycar DFA or SAFC you are smarter to do that...
ahhh, silvia owners. Got to love it.. where their wallet is as small as their brain..
you might want to take that back moron.. sure some silvia owners are stingy bastards but you gotta remember were not all like that
im also sure there are skyline owners just as stingy out there aswell
asswipe
Wazz
Edited by Wazz
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
