I was at the place where i get my car scerviced today and there was a kid there with his silvia on the dyno.
I got to talking to him as he was tuning his car and i was curious as to what he was doing.
He was doing a power run, looking at the AFR's and then putting a resistor between the AFM and the ECU!!!! he would do another power run and check the AFR's.
I informed him this would lean out the AFR's right accross the range and he looked at me like i was an idiot!! and said to me Look at the afr's man, its rich right accross the range, sure enough he was right!!!
He was upping the resistance value each run by 0.02 of a watt.
I saw the figures, before and after, and he went from 152rwkw to 164rwkw and his afrs were still below 12:1
He said by doing this he had illiminated boost cut, advanced the timing, and was using less fuel.
Not bad for 6cents for the resistor...
why is it stupid if done monitoring the AFR's?
it is doing the exact same thing as a safc except right accross the rev range. and providing you don't go too lean what the hell is wrong with it?
I think in the right application it is fine.
I mean, if worst comes to worst hes only going to blow up a CA or even better an SR. Good for him!
At least he is smart enough to test it, not just read something on the net saying use a xx resitor, it will help.
I wouldn't use a pot, apart from getting the right value, as there's vibration, moisture issues etc...
Once you have the right value, measure the resistance, then put in a fixed resistor - You don't want your afr's changing at every pothole, of it it rains :-D
yeah thats what i was thinking about a pot. as soon as you bump it you lean out.
CA's have feelings too! just because they are a bit "special"!!! there seems to be no love for the CA anymore:(
Its just as dodgy as bleed valve boost control. Plenty of people use that without concern.
Both too dodgy in my opinion, but those using bleed valves for boost or fuel cut defender are just as bad. He is loosing flow of electricity instead of air.
[qoute] Its just as dodgy as bleed valve boost control. Plenty of people use that without concern.
Both too dodgy in my opinion, but those using bleed valves for boost or fuel cut defender are just as bad. He is loosing flow of electricity instead of air. [qoute]
haha! that means I am a bad man... I have a turbotech bleed valve, I am a very bad man...
BMW's group A cars back in the 80's were tuned using the same method, it worked well for them.
Thats very interesting. I used to love those John Player Special little black BM's:)
Edited by CEF11E
*sigh* i love these types of un-educated comments.
How can you even remotely say that?
I was running a bleeder of my gate upto 24psi... 7psi through the valve and a hold in the line for a bit more
It never spiked, never changed the level of boost, never gave a reason for me to think i'd wasted $10
Correctly done a bleeder can be of the same level as an EBC without the mammoth expense.
I'll point out what i see as an issue with this idea.
he is adjusting the AFM reading accross everything. It is not dependant on RPM / Load / Temp / Conditions.
Sure he is testing on the dyno I assume full power runs at full throttle.
I would say he could get that quite right.
I doubt he tested all rpm / load conditions at all temps.
If he leans it out with this method, everything is leaner !!
Things like close loop driving will be leaner. Light throtle leaner. Cold start leaner etc etc ....
Sure he can leave a "buffer" but as you can imagine it would not be an ideal way to do things.
Closed loop wont be leaner. It will adjust fueling based on 02 sensor output!!
It's dodgy but hey if you dont go too far it should be ok. I mean you wouldnt do it to an expensive engine..
for the cost of a jaycar DFA or SAFC you are smarter to do that...
ahhh, silvia owners. Got to love it.. where their wallet is as small as their brain..
you might want to take that back moron.. sure some silvia owners are stingy bastards but you gotta remember were not all like that
im also sure there are skyline owners just as stingy out there aswell
asswipe
Wazz
Edited by Wazz
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
