ummm. no.
Everyone else here reads this forum too.
Based on what ive seen or done myself, ill pass comment on it if i know a bit.
There have been a number of people (on this very forum if you read most threads) that have tried this to get next to no gain.
So is that money justifiably spent? Not really.
Funny you found a thread in another section... heaven forbid should it have involved the search button :P
If your bitter about the RB20 head on a 30 bottom end. Thats your problem.
Dunno how many people in that thread told you its a waste of time how many diffferent ways?
dont bother posting if your going to whinge at the responses
The Exh Cam gear on the Neo Engine did absolutely nothing. Cost me $600 worth of fitting and dyno time, and did nothing.
On the non Neo, apparently it can give 5rwkw through the midrange and a little bit up top too, but it's probably not worth the effort.
The cost and effort required to pick up 5rwkw isn't really justifiable.
IMHO
BASS OUT
ummm.  no.
i'm not bitter about anything, i just think your an arogant, ignorant, idiot on a moderator power trip. i havn't had a problem with anybodies replies bar yours.
anyway, fitted it all up today, seems to pull alot harder. i'll try to do do 0 degrees and 4 degrees consecutive runs when i get on the dyno, should be in the next few weeks. anyone know where i can get an safc2 for a good price
All you're doing when you retard the exh. timing is creating a bit more exaust pressure through the turbo hence the quicker spooling and improved mid-range torque, on the neo engine it will do squat!
The only problem with that is if you retard it too much you go backwards in power because the engine is working against itself trying to push exh. gas through an unopened valve.
You only really need adjustable cam pulleys when you get aftermarket cams that have a lot more duration than standard so you can finely tune the characteristics of the power band to get the most out of it.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
