Guys,
I went out lastnight at around 8pm, seemed fairly coolish so I set the EBC to 0.8bar andway was giving it a bit of stick and the car started to detonate. So as soon as it did I took my foot off the accelerator and dropped the boost to 0.6bar. A few guys run bleed valves and stock I/C's do you guys detonate as well?
https://www.sau.com.au/forums/topic/9618-intercoolers/
It will depend on the car, I ran 1bar on my stocker with no troubles, but in general unless you have tuned the fuleing to suit that boost then I would steer clear. On a stock turbo running 1 bar means that the pressure at the turbo is far higher, and it just ends up producing heat, which is what causes the detonation. Get a FMIC and 1bar is no probs.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9618-intercoolers/#findComment-146666
Originally posted by rev210
Not the intercooler!
plugs too hot? (go a colder set)
Too much timing?
wot r u refering to?
Too much timing u say? u say he runs standard?
Skys ecu is tuned for 100ron and u think that RON98 is really 98 points?
Not as far as people tell me its not!
So hes pinging either like he said, cooler not being efficient, a little bit too much timing in the higher revs, plugs not gapped properly causing combustion chamber to preignite because of the large gap that the coil has to generate a spark.....and more..
https://www.sau.com.au/forums/topic/9618-intercoolers/#findComment-146987
I know the consequences of running too much boost and high intake temps... what I dont understand is why so many people persist with bleed valves and stock coolers. With bleed valves it will spike to probably more than 1 bar and is hardly as controllable as a EBC. Just wandered how many people did it and why?
https://www.sau.com.au/forums/topic/9618-intercoolers/#findComment-147027
Originally posted by Steve-SST
Check the pressure drop across your core see how how much boost your really makin to get 1 bar out the other side of a GTS
core, thats why the airs so hot.
What are we actually talking about?
Everyone knows tht the stock IC on an R33 gives about 6psi drop over 15psi equalling about 21psi of course the IC is saturated and causing a huge pressure drop and heat increase but we are talking about other variables here.......none of this is extra ordinary :eek: :eek: :eek: :eek:
https://www.sau.com.au/forums/topic/9618-intercoolers/#findComment-147060
Originally posted by macka
U like to point out u only run 10psi hey....
girl! :lol:
No...but I'm thinking I should now.
Yes, there must be something to enjoy about pointing out the fact that you 'only run 10psi'.
Perhaps its the way you point it out?
You can say it:
..with contempory dance.
..with an artistic arrangement of pocket lint.
..in music,that when played backwards says ' I only run 10psi'
..by cross promoting with Mac Donalds, the '10psi burger' - guarenteed to produce flatulence at or below 10psi.
https://www.sau.com.au/forums/topic/9618-intercoolers/#findComment-148888
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
