Hi
I've just taken the door trims off and decided to have a look to see what was causing these scratches. Well the scratches are comming from the window seal strip on the outside door panel. I've attached a photo showing the problem.
What can I use as a replacement for the worn out guides? It's kind of like a fibre cloth material, I tried some foam but that doesn't work. Any suggestions?
Thankyou
https://www.sau.com.au/forums/topic/96217-r32-window-scratches/
i also have the same problem on my r32. i havent taken the door trim off yet to investigate but i think it will be a easy fix. perhaps some felt glued to the inside of the seal will help. i am actually more concerned about getting rid of the scratch marks left on my drivers window. any suggestions? ;)
