Stolen : 1995 R33 Gtst Series 1 White
Coupe-This
 Share
Got home about 11 last night thursday the 24th of november, got up morning, didnt think it was any sort of a different day.
went out to get lunch to notice my car not being there. Rang up my sister. Said my car wasnt there when she left, i was up until 1230 so the car had gone missing between 1230 and 11am the next morning.
The plates on the car are swp-315, the front plate is a slimline and is offset to the drivers side, the front bar had been slightly modified although there is NO front mount intercooler hence there being a massive gap...which may stand out to some people. (refer to pic in sig)
pictures here
http://www.cardomain.com/ride/2130038
its a stock car, clean... stock rims, gtr spoiler, mspec bar and sideskirts, had a catback exhaust.
ummm yeah ...
car got stolen from malvern (who would have thought)
im shaken up and pissed off as well :(
Edited by Coupe-This
  • Replies 58
distinctive tail lights too... so if u see someone in an R33 with the lights on and only the outside lights actually come on in the rear then follow the biatch!
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
