I drives a R34 GTT Manual, and I got offers for Blitz intercoolers (new + pipping) that is kitted for the ER34 . However I found an aftermarket for GTR HKS Type R (2nd hand) which is price much lower but I have to do the piping myself yet still cheaper than the Blitz. I was told that the HKS would give me lag.
Which one would be a better buy in the long run if my goal would be around 400-450ps in the near future?
Thanks in advance. Cheers!
https://www.sau.com.au/forums/topic/96228-blitz-or-hks-intercoolers/
Why would one give more lag than the other? Does it have an extra 2 litres of internal volume?
Id expect either would be fine for your goal as they are both name brand cores and good quality, assuming they are around the 600x300 core size (which is just about an industry standard these days)
Thanks mate for your feedback.
The reason I was told about the lag is the piping for the blitz is shorter since it will continue halfway from the existing stock piping and go underneath the intercooler to join the other far end with a 180 turn piping. Where else the HKS intercooler needs the piping to be specially made coming from left through the battery base(bore a hole just like GTR piping arrangement). Would the minimal extra length, will i get more lag?
Honestly, I prefer the HKS Type R for the price but the Blitz is new...so getting confused.
The HKS Type R is for designed GTR's as it's a lot thicker than the Blitz (100mm vs 70mm) so you may have trouble getting it to sueeze in the ER34 bay.
Another thing, even though the quality is great I found my HKS one damaged VERY easily and within 3 months the fins on the front were really damaged, so I've bought a Bar/Plate design instead which is less prone to damage.
so these intercooler kits fit straight flush, no cutting of anythings esp front bar and that?? im looking at a intercooler kit, wanting jap brand, but dunno wat to get...i like the blitz cuz it has stockish piping...is arc worth it?
I Believe apexi, hks and blitz all make a kit that uses the stock piping..
I think the apexi one was slightly more expensive by like $200, and the cooler itsself looked smaller than the blitz one.. so i got the blitz one :wacko:
I currently have a custom 600x300x100 cooler (using a PWR core) and had no problems with fitting. Even used the factory holes for the piping.
As for cooler choice....if your looking at changing the plenum in future id say go for the HKS out of the two.
The blitz one from memory has a bend on the drivers side end tank so it would be very difficult to modify the piping to suit an aftermarket forward feed plenum.
On the subject of plenums though..good luck with the neo engine.
Ive been looking for quite some time now for a suitable bolt on type plenum and there is not much out there.
yeah the volume is the same... but the air travels through less piping to get to the TB..
if you were refering to my second post 2nite :wacko:
I think if u measured the piping it would be the same volume as the other kits.
Doubt there would be much diffrerence there.
I got the blitz one. MINT
The blitz piping has 3 turns.
The one which goes around the fan has 5 turns.
Conclusion blitz has less lag cause of the less turns and shorter piping.
Also a cop wont like the look of a huge pipe running around the engine, unlike the blitz where you dont see nothing from the engine bay.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
