yes
what you need is
BNR34 Getrag 6MT gear box (Nissan list price is aorund 458000YEN)
Nismo propeller shaft (part no: 37300-rr595) 95000yen
Clutch for BNR34
Set of Final gear (or you can use BNR32's 4.111)
will cost u about 10k fitted?
yes
what you need is
Clutch for BNR34
Champion !!!!!!
I will start saving, that is something i would really like to do,
appreciate your help mate.
steve
One needs to ask the question why you want to do this...
R33 and R34 gear ratios are :
1st : 3.214 / 3.827
2nd : 1.925 / 2.360
3rd : 1.302 / 1.685
4th : 1 / 1.312
5th : 0.752 / 1
6th : N/A / 0.793
You are basically going to have a very tall 1st gear (might be pretty useless if you don't change diff ratios) and squeeze another ratio in between 2nd and 3rd. Your 4th and 5th is pretty much equal to getrag's 5th and 6th.
Is that really worth the estimated $10k...? (I'm thinking would even cost more than that)
There are a lot of power mods you can do with those $$$.
PS: You don't need the R32 final gear as yours is identical (4.11).
R34 final gear is 3.54 and if you decide to change the rear diff ratio, the front one has to be changed as well.
