Hi guys,
Just quickly.....
I have my engine in pieces and was going to use the stock pistons again because they were in great condition... I now want to put forgies in.. I use my car for work and need this engine back in one piece ASAP!!
WHERE the hell can I find someone who makes pistons for the RB25DET on the net????
Do the pistons for the RB26 fit the RB25?? I'm sure they have the same bore...
Any help would be great..
https://www.sau.com.au/forums/topic/96267-need-pistons-quick/
Thanks guys....
I'm looking and looking on the net... I'll check out those guys you noted...
I've found that Weisco make them but they are $960 american... sound a bit pricy.. I know I can get them cheaper then that..
I personally wouldn't go forged pistons UNLESS the power I was making requires forged rods.
Stock pistons providing the comp ratio is good (no higher than 8.5:1) is reliable, as always it depends on the tune, forged pistons wont protect you from a bad tune/detonation.
thanks for the offers.. I've actually found some Weisco forgies... (private sale, new in box... $900.. Bargain!!
The reason I'm getting forgies is because I'm building the block up for higher boost and I don't want to have to strip the block again so while I'm rebuilding the motor, I might as well do it properly....
Thanks for the advice though guys...
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
