guys what is the main diff between the 2 turbos below:
HKS - GT Sports Turbine Kit - 2835
HKS - Turbo Kit - GT-RS -
now why i ask is apprantly there both rated at 400ps.
so yeah me confused.
anyhelp would be good ;)
thanks in advance
Actually both use the Garrett 71mm GT35 BCI 18 series compressors in 52 trim though optional on 2835's 48 and 56 trims .
Main difference is the turbine , GT-RS is the fancy name for a Garrett GT2871R with the middle or 52 trim compressor . All 3 2871 cartridges use the 53.8mm GT28 turbine in 76 trim (NS111 type) . Also avail in 48 and 56 trims .
HKS GT2835 and some Garrett GT3071R's (WG type) same cartridges use a 56.6mm cropped GT30 UHP turbine .
The theory is larger turbine makes for better "balance" of compressor to turbine size ratio .
Make careful note that HKS generally stick to smaller trim compressors than Garrett do - the result is better response or lower boost threshold if you like .
As for the 400PS , the GT-RS would be on its knees from a turbine inlet (back) pressure point of view .
PM me if you want all the numbers n bits n pieces .
Cheers A .
GTRS's on gtr's are capable of much more than 300awkw. how ever were talking about just a single turbo kit.. the disco potato is a GT28rs rated between 320 and 350 from memory and they are a excellant turbo for a sr20 for response
from memory there was someone of the forum makeing 270rwkw in a 33 gtst with a hks gtrs and suitable mods to go with it
Wazz
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
