just wondering how dome of you guys with big turbos like gtrs's and 2835's go with fuel does it guzzle or all depend on how you drive it, as i am looking for aturbo upgrade but i dont want it to suck 22ltr/per 100kms :lol: .
thanking you :)
https://www.sau.com.au/forums/topic/96337-fuel-economy-with-big-turbo/
It really depends on how you drive it.
While i have a gtr, i do have upgraded turbos. and i can say effectively, that if i proceed to rev it out, such that i am at full boost @ 4500+ rpm in 4th, then it chews petrol like anything. however if i stay on minimal boost at lower revs, it probably chews less than it did standard
Before I pulled my car off the road, it was running 2530's with about 18psi boost, cams, power fc etc. If I flogged the guts out of it, fuel consumption would be terrible (I think my best effort was 180kms off a fullish tank, about 65 litres).
If I babied it I got pretty good fuel consumption... thats why it became a weekend warrior :)
Going the big single now, so I expect fuel consumption to go out the window even worse when im giving it a hard time.
Depends how you drive really
For example, with stock turbos i had full boost around the 3000 or so rpm mark.
So the engine would chew through more fuel because i would be making more power at 3000rpm than with my current setup. Therefore, better fuel economy.
However, At the moment, I am at about 85-90% capacity of my 700cc sard injectors at full throttle/boost, over 6000 or so rpm, so fuel economy goes through the roof
Yeah i would have thought you would get better fuel economy everyday normal driving as a bigger turbo would be a bit laggier and not making boost until later compared to the stock turbos. Therefore less boost = less fuel used.
A GT-RS isn't a big turbo i don't think...
I've got a T04Z on a RB26, and its fairly heavy on the fuel. 16-18L/100km at best estimate.... would definately suck a tank of fuel very quickly if you're heavy on the foot. You're looking at significantly less power with a GT2835R/GT-RS so you've got nothing to worry about ;)
Fuel makes power :)
All depends on your right foot. I have gone past 400 kays with my new 2835 and economy is normal - that being around the 500k mark / tank no problems.
Driving with my lambda sensor has also made me aware that even out of closed loop I still am getting 14.7 - 15:1 AFR's at these light load load points.From what I've seen the PFC maps seem to deliver great fuel economy
If you boost it up and make it go into higher load points your economy will allways suck.
With the RB20DET I was able to rev the crap out of it on 1bar of boost all the time and still manage a decent 470km's per tank.
Since the RB30DET has been dropped it it boosts much much earlier, even just driving around on boost with the odd wot every so often the best I manage is 430km's per tank.
This tank i've only managed 370. :)
I have been stuck in to it quite a bit though.
Unless your driving around on full boost. (Which will be quite difficult to do on the street legally)
You shouldn't really have any fuel cosumption increase.
I mean i don't know about RB26, but on my RB30 i can drive around all day everyday off boost if i want.
I think its how your engine makes its torque that has a lot to do with fuel consumption . Others on this site have said power from aditional airflow is the go rather than extra boost .
My idea is to have a reasonably healthy compression ratio (~8.8/9.0) , a head and valve train that breaths well without long duration wide overlap cams . A turbo with efficient wheels and a very good balance of turbine to compressor .
I believe the road to good power and fuel consumption is a state of tune that gives good part throttle torque particularly off boost - in other words you don't need to go chasing revs and boost to get it to go .
I think we can safely say that engine management/cams/turbos and pump fuel has reached the stage where you can have a decent compromise for the road .
In my book things that hurt reasonable consumption are :
1) Gutless low CR ie under 8.0
2) Long period cams with lots of overlap - lack of cylinder trapping efficiency and
reversion .
3) I'll start a fire here , cams as above with single throttle plenum manifolds
promote pressure fluctuation in the plenum enhancing reversion .
4) Turbos that allow much higher exhaust manifold pressure compared to inlet
manifold pressure under boost . It takes crank energy to force exhaust out
through restrictions . Fuel energy generated crank power that could have
been used to drive us down the road . Exhaust reversal back to the chambers
because of restrictions , polutes preheats and drops the fuels effective octane
rating meaning less ignition advance can be used - hurts consumption .
5) Tuning - the method of load sensing and the flexibility of the computer itself is
very important . I'll be going with hotwire AFM's because they have the best
handle on air temperature vs density , I think MAP's a bit crude . So that leaves
me with either std retuned ECU or Apexi PFC , PFC all the way .
Lack of experience of the person tuning it - this hurts at the pump big time .
My opinions only , feel free to change them .
Cheers A .
Just came back from a 425 k cruise with a lot of spirited driving and a few big squirts - still had just under a quarter of a tank.
bloody hell, im running a stock r33 s2 with just 4" exhaust (from 3"cat) 10psi boost and power fc and i can only get 360 k's out of it max even driving like a ganny most the time
you guys reckon the big exhaust has somehtnig to do with this or not?
360kays sounds like you either really get stuck up it ever single acceleration OR the light load cruise etc is totally out of wack, being influenced by the O2 sensor etc..
My 3ltr DET running 12psi and stock rb25det base map (untuned) gets better than yours. :S
Edited by Cubes
    • Yeah, thumbsup from me. The distant shot of the bay just looks same-same as before.
    • Dad had a court case drag out with them from 1998 to 2004. He was in a not at fault accident, NRMA were the ones who covered the other person. They tried to blame his neck injuries on the fact he'd had an injury in 1981 on his extreme lower back where he slipped a single disc right near the bottom. Had been all cleared from that injury for years. This accident destroyed his shoulder, and f**ked a heap of discs in his neck, and he still has major problems with it to this day. Sarah's sister while on her L plates had a small Suzuki Alto, she had stopped to give way to an ambulance, and someone changed lanes behind her because there lane was also slowing, and rear ended her at 80km/h. (She had been stopped for a few seconds already too!). Car was completely f**kED. NRMA sent the vehicle around to 3 different workshops as they kept claiming "We believe it can be repaired, and not written off, we just need to find the correct workshop". It took 3 months, and a lot of arguing before they'd concede and wrote it and paid out. About two years later her sister had a Lancer, someone pulled out of a stop sign without stopping (in an 80 zone). Her sister swerved, hit the front of the other persons car (Instead of dead t-boning the drivers door), which ramped her Lancer, and made it roll multiple times down the road. It hit every panel on the way through. Her sister had slid her self out of the car, and remembers the ambos walking to the accident (They'd been sitting at a set of lights just down the road and witnessed it) and they were saying "Well, this ones going to be a fatality, no way you can walk away from that". Well, she did. And then NRMA sent two assessors out to look at the car, both of which wrote it off. They tried to send another assessor out, except a HUGE uproar was raised, and they FINALLY paid it out. That was on a car, that had damage to EVERY panel, you could see from 100m away the whole car was also twisted, roof bowed etc. Nah, we'll try get out of needing to payout on a $10,000 car... Her sister ended up with major shoulder reconstructive surgery being required, and was permanently limited in her ability to do her job as a nurse after that, as she can't (And was told before surgery too this would be guaranteed to happen) regain full strength in that shoulder. However, there was no choice to not have it, as she could barely use her arm, which was her dominant one, and was in near constant major pain. (And she's the type of person that would try and walk off a broken leg!) NRMA did the biggest run around on the personal injury side too for about 18 months, even to the point of trying to put 100% blame of the accident on Sarah's sister, even though the other driver admitted she didn't look, and didn't stop, and was charged by the police. Sarah used to have a Barina insured with them. It was a policy setup, paid all 12 months in advance. At the end of the 12 months, Sarah was living with me, I reviewed the renewal, it clearly stated "If you do nothing, your policy will cease on XYZ date". We did nothing, as we moved her insurance in with all of mine and I was with Shannons. We find out 10 months later, NRMA decided, because he DAD had a car insurance policy at the same address as what Sarah's mailing address was (Garaged address had been changed), that they'd put Sarah's (What should have been non existent policy) onto her Dad's month to month charges on his credit card. We had to jump through hoops, to get a refund. They didn't care that we actually found the letter that said "If you do nothing, your policy will cease" they made us prove we had NON COMPULSORY insurance else where before they'd issue the refund, and after they agreed to the refund, it still took another 6 weeks and 3 more phone calls for them to actually process it. They also had two insurance claims from storm damage, and they were an absolute cluster to get resolved as well (one vehicle, one house). Some how, up until about 3 years ago, her parents were still loyal to NRMA too, and we were like "How the hell are you so loyal to staying with them, when other places are so much cheaper, and they've f**ked you over every time you've ever had to make a claim?"
    • I got the four AN10 fitting welded up to the cam covers and started up making the head to sump breather/drain lines. The front passenger side cover I used a 45 up top and a 90 at the bottom into the stock VCT head drain spot (3/4" BPST to AN10 adapter) thats unused on the RB25DET NEO with some speedflow flame shield to protect it from the manifolds heat.   back passenger side was a 90 up top with some flame shield and 45 at the sump end. The rear drivers is 45 at both ends   the front drivers fitting is capped off for now but ready to go if i want to try moving the breathers around. I was told by the fabricator to leave all the welds raw for now to make sure there are no pin hole leaks. A lot of cleaning up, re bundling looms and degreasing to go as well as final assembly on the cam cover baffles. The first real test will be 28th March at a Circuit event. added complexity and more spots for leaks but overall looks relatively neat imo
    • Yeah i think the dash needs to come out. To get the loom or maybe just climate control and radio cluster. My mirrors are done i think the motors don’t work so well after flood haha i need the ac fan, you said you wanted to keep it for your 31 and interior loom not including boot. The wiper motor. I’m not sure how good the window surrounds are on the exterior on the pintara.  I will message you to get your bank details shortly
    • Just another barrier put up to stop cars being modified. When we're all driving Chinese sewing machines, you won't want to modify it anyway, and you'll likely already have slashed your wrists and be locked up in a padded room for your own protection.
