I think Sydneykid said if your engine is into boost at freeway cruise speeds , like every time you breath on the pedal for a hill , the consumption will be poor .
Cubes may have found by using the larger turbine housing the boost threshold is higher and exhaust restriction lower . If the final drive was raised to 3.7/3.9 the car could use the extra torque it makes at lower revs to get better mileage .
O/T but notice how the R34 GTt uses propper variable cam timing and makes good torque even with the larger turbine housing . The effective or dynamic CR is probably better that the GTS25T at the low end so does not need the early onset of boost to get it going . Has anyone compared consumption on a 33 and a 34 ?
I'd like to know what the aftermarket VCT does to a GTR from a power and consumption point of view .
Cheers A .
bloody hell, im running a stock r33 s2 with just 4" exhaust (from 3"cat) 10psi boost and power fc and i can only get 360 k's out of it max even driving like a ganny most the time
you guys reckon the big exhaust has somehtnig to do with this or not?
Hi there,
No don't think the exhaust has anything to do with it.
More than likely that your tune isn't the best - I doubt it would be the oxygen sensor (please correct me if I'm wrong!) as with mine turned off at light to moderate loads the AFR's are pretty much the same as with it on. It would be interesting if you could go for a drive with a lambda sensor to see what's going on - getting that done at a shop would probably end up paying for itself with the fuel you may save.
Something I did notice about the other guys I went on the cruise with is that they are always in a low gear giving it a rev.
No good for economy.
Strange that you get such bad economy with a 10 psi tune though - who ever tuned it wouldn't have had to change the maps too much and mine got excellent fuel economy with the factory apexi maps!
Cheers
Hi there,
Cheers
Mercury tuned it, twice actually lol, wasnt all that happy with the first but they werent able to do a road test/tune, n still not fully satisfied, but will wait til i get the fmic on n go back.
Also we had huge problems with it running heaps rich, but it should be fixed now, also when i put the new dump pipe on the 02 sensor was chalked up with heaps of carbon, but i cleaned it all up n looks ok
lambda sensor what is it n what does it do?
P.S. sorry for highjacking the thread :lol:
Lambda sensor is one of those sniffer things the dyno guys put up the exhaust so they can check what the air/fuel ratios are.
Id say you'll get better economy with an intercooler and dump.
If it was running heaps rich then maybe your O2 sensor is buggered.
getting about 1.2ltrs per 1.1kms at morgan park on the weekend. rb25det with about 350hp @ rears...almost always on boost...martini 110 race fuel...expensive shit..and we went through it like no tomorrow..used about 80-90 litres for about 79 laps. lol 150 bux per 20ltr drum.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
