  • Replies 85
Posted Images
I did it today and the noise is good ppoorrsshh but I miss the pphhsstt.
What will happan if I disconnect the return air(from bov to mouth of turbo)and let it free to the atmoshere,will it stall and piss fart around and will the noise be louder btw it' a RB20.
Can you submerge the outlet in a glass of water, then blow thru the small hole next to the valves diaphragm. Do up see bubbles
Im curious to know if the OE BOV has a check valve in their somewhere. Or have you checked that irresprective which end your blowing in, air still passes thru.
Good find.
Good find.
G'day Roy,
Yepp, it flow's both ways. I checked this out just to make sure. Strange hay. Not sure what it's meant to do like it is, maybe it makes the transision from BOV closed to BOV open smoother or something? I don't know... But mine does feel a bit snappier while on boost.
R31 Power - if your ECU is anything like the ECU's on the R33 and R32's then you might get the stalling and overfueling problems that some of the other blokes have had went they run a BOV that vents into the air. :)
  • 9 months later...
Well i cant say i am a fan of this idea. I tried it myself and u can notice its doing something different. I noticed when adding slight throttle from say a cruize situation the accelaration is upped as the bov cant leak excess air back into the chamber. This is i think a not so good thing. Didnt notice any differences in performance when in full throttle position though. I went to the track with it blocked off and on my last run unblocked it, taking it back to stock and i ran .4 of a second quicker. Not sure if the 2 are related but i am not convinced this mod does anything sufficient
I also tested this mod the other day on my R32 GTS-t using a piece of tape to cover the hole, the BOV definitely sounded different....For a start - less air recirculation sound when the turbo spools up, normally when venting the BOV sounds like this: WWTTSSSSSSSSSSSHHHHH, afterwards it sounded the same at high rpm/boost but on a light to midrange throttle backoff it would flutter (kinda like this: TSHH TTTT TTT TT) and caused the motor to hesitate slightly.
I removed the tape and the hesitation disappeared and the BOV sounded as normal - so I can't say I was all that impressed with the result, but it is interesting how different ppl have had totally different results!
I did the mod and my BOV sounds pretty different. Not a long pssshhh anymore. More of a quick sshtt and thats about it. Doesnt sound as nice. But it does certianly hold booster better. I'll be leaving it modded!
Guest RedLineGTR
It's not actually a leak....Nissan put it there for a reason. Did any of you happy little modders find out what it does before you changed it..........Just curious... ;)
From what i have noticed and heard also, it is designed to stop boost hitting so hard when it kicks in gives a more smoother boost delivery when boost is created it does it by bleeding abit of the air.
i really want to do this mod but whats the conclusion result? should i or shouldn't i?
I think it really comes down to personal taste and your driving style.
Some people like the way it feels once modded, others don't.
The biggest difference I found (in my car) is that it seems to come on boost harder and a bit faster.
When I had the car on a dyno, the operator was supprised to see my car having useable boost at 1800rpm !! And looking at the dyno printout, it goes from 46rwkw at 60km/h (4th gear) to 90rwkw at 78km/h. That's close to double the power in 18km/h - I better add in a comment that I'm not interested in the actual amount of power, but it's the power curve that is interesting, otherwise I know it's gunna start up that "can't trust dyno's" crap...
And all I had was a 3 inch exhaust, FMIC, 12psi and the BOV mod.
So as you can imagine, having more power lower in the rev range makes the 'power band' bigger. Well that's my theory anyway.
One question I do have though, some people have mentioned that doing this mod takes away the linear feel of the throttle. Does that mean that everyone that has a after market BOV that plumbs back get's the same results?? I've never used one so I wouldn't know.
J
  • 1 month later...
yeah i have changed my mind, i did this mod again out of pure boredom at home, and have been monitoring it, i notice its more snappy onto boost, and not asmuch throttle needed to continue motion. Liking the noise too.
That's great news freebaggin - thanks for going to the effort of doing a comparison.
J
Thanks to you for sure, I had basically forgotten that the stock BOVs leak and your post promted me to do something about....fantastic result for the cost and effort involved!
Freebaggin, very interesting stuff indeed. Btw Im interested in seeing the boost curves. It seems as if the latter run was running a smidgen more boost, well just seems like it anyway...
Good stuff!!!
Good stuff!!!
Well I suppose it's more that the turbo might be running more efficienctly as well, not having to increase shaft speed to counter the bleed of and as the boost chart shows, the curve is a smidge more consistant and maybe that's all the turbo needs to provide better grunt..???
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
