There are a lot of turbos that can look legal, Hi flow is the best from that perspective as it is all in the original housings, then there are the HKS 2530 2535 2540 and GTRS that all bolt on in the shock position and would I imagine fit under the heat sheild with a little mucking about, Another option is the Apexi AX53B70 P25 which is similar to the HKS ones, there are also a few garrets that are around the same specs and sizes the HKS ones mentioned, so there are a lot of fairly inconspicuous turbo choices around! As for the legality Im not sure as it would depend on the state you are in!
most of the other parts you fit with the "bigger turbo" aren't legal and you will get defected for if they aren't hidden. things they will look for:
1) unplug afm and see if car stalls
2) check for ecu under kick panel
3) pod filter in engine bay + aftermarket intercooler
4) boost controller (coloured tubes and wires going to turbo area)
5) exhaust too loud / and or black stuff on rear bar = dead cat
so you could fit a hiflowed under the heatshield and it will be fine and no one will be any wiser, but if you have a boost controller clearly visible with a pod and fmic then it wont mater as those are illegal/defectable
is any form of aftermarket turbo legalish on r33 ,and would insurance for example with justcars cover you anyway.
In NSW, there are a number of modifications that are 'owner-approvable'. These things include
exhaust (within noise limits), wheels (within size limits), suspension (within height limits, afaik
you can't change the geometry and you can't cut/weld stuff).
There are probably a few more, the place to check is the RTA or your state's equivalent. These
things are also changing (something about a 'signature note' on exhausts).
Any other modification (in NSW) needs to be engineered. So in NSW you need to have turbo
changes engineered. I understand that Vic is _more_ restrictive about mods; so the best thing
to do is check with your RTA equivalent.
Justcars have some interesting wording; they let you 'nominate' any type of mods (like, for example,
ECU) _but_ they say that it must be a 'legal modification'. Now to my knowledge using turbos
that are different-to-stock requires engineering to be legal, so without the papers they could
very well turn around in the event of a crash and say 'no, you're not covered because it's not
a legal modification'.
That being said; I had occasion to claim on my original GTR after I put it in a ditch. It had pods,
ECU, boost controller, exhaust - three things requiring engineering in NSW but that I had no
certificates for. They paid up with no fuss at all, and in a timely fashion. The best thing to do is
to ring them _before_ you make the mods, tell them what you plan on doing, and ask whether
you will be covered or not - preferably in writing and get the answer in writing :angry:
Regards,
Saliya
My understanding of things, which is from a NSW perspective (but the draft oz wide mod rules are very similar to these so watch out those of you from other states), is that the big problem is proving ADR compliance, specifically ADR37 (which includes drive cycle testing).
Factory turbo options comply with ADR37.
Some of the more common turbo kits *may* have been put through the testing if the company putting the kit together have gone to the right amount of effort. Since we are talking imports, then it's unlikely there is any "legal" (as in ADR37 legal) kit for a skyline.
Anything DIY is almost certainly not legal. Even though it might pass, it hasn't been proven to.
Edited by browny
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
