GTSt SONY setup
Guest alexR33
Hi !
I promise to be brief!
Hypothetically if i could ONLY get SONY...So don't tell me sony suck. in this siituation ONLY SONY exists. What would you suggest out of the current range, including specific models for Head Units and splits, subs, etc. To set up a R33 GTST Series2, I have some speakers 6x9s already for the back, just want a DECENT set up, nothing that wins comps, but cost effective and something the average person would be impressed with! Only sony. I can buy direct off a mate. So that should explain that...
To be completely honest, i know very little about what the different specs all mean. I'm only after one suby and tweeters and splits and a hhead unit and amp i think.
Thanks for your time!
Alex
https://www.sau.com.au/forums/topic/9638-gtst-sony-setup/
Depends whether you get a real discount or you just think you're getting a discount 'cause he says you are :)
You did ask for Sony only, but i'm gonna say it anyway.
For that sort of price everything in the Pioneer range (or many others) is better..seriously, i owned some Sony speakers and they weren't too crash hot - and then after a couple of years of amp'ing they started going cactus... and i'm not even a massive volume person. I'd really reconsider the Sony unless you can get them for some massive discount (50% off or something)
Other cars with Sony stuff have not sounded good to me either. If you're going a full setup, don't just buy Sony if you're going to spend $2k or so or the lot.. a lot of the Sony stuff is more expensive than other equivelents in the first place so you might not actually be saving that much.
https://www.sau.com.au/forums/topic/9638-gtst-sony-setup/#findComment-148339
Whats the chances of you gettin me a Sony TV???????
Sorry guys i disagree, cos ive had SONY all my life in my 33 and in my house and ive had no problems, and the sound of when i had just one 12 inch sub in a chipboard box a couple of years ago was unbelivble.
But hey everyone is entilited to there own opinon.
https://www.sau.com.au/forums/topic/9638-gtst-sony-setup/#findComment-154846
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
