Hey everyone
Just some questions to see if any1 can help.
My car was recently dynoed at 175rwkw at 10psi. Its got a front mount, 3" from the turbo and some other stuff.
I was told that i shouldnt go any higher than 10psi because stuff could snap. The previous owner said he could run 14psi on a bleed valve.
What else can i do to get some more power? i was hoping to get around the 200rwkw with the boost controller but yet...
what else can i do to my car?
cheers
https://www.sau.com.au/forums/topic/96385-rwkw/
Yes but wen you do that you can hav problems
There is only so much you want to run
After that engine blow up will be around the corner and rwkw does not mean you have a good car t drive
Power with power band is wat you need
james
https://www.sau.com.au/forums/topic/96385-rwkw/#findComment-1747360
cant i increase the psi higher than 10psi?
not on the stock turbo. 10-12psi is where its making its max power without putting too much stress on it. Ive heard that running more than 12psi through the stock T3, wont achieve much of a power gain anyway. and that running anything higher than 14psi for extended periods will kill the exhaust wheel.
https://www.sau.com.au/forums/topic/96385-rwkw/#findComment-1747363
200 +RWKW.
Back in the early days of messing with the rb25's we found that anything over 12lbs wasn't a very good idea, as it places too much strain on the std bottom end hence doesn't promote longetivity.
We found using a high flowed std turbo using a front mount, full 3" exhaust , pfc, boost controller would run at just over 200 rkws but would then run in to issues with fuel pressure etc, so i would recomend using a good quality fuel pump and pressure reg at the least but injectors if you can afford it. When its all said and done you cant axpect to get much more out of a std bottom end and have durability and the ability to be a daily driver etc. Thats why the blokes that are deadly serious about racing etc use os gkn motors that have nearly indesructable bottom ends etc to run rediculous amount of boost.It's also the reason i have built a stout 3ltr motor using good quality internals that will comfortably handle more than 2bar of boost when required.
Regards,
SKYLINE...(Kym) B)
https://www.sau.com.au/forums/topic/96385-rwkw/#findComment-1747970
    • Damn, as someone who just glued the damn things in (very slightly askew but better) I wish I saw this, or someone made this. Would be worth linking this to Boosted International. They're always looking for product ideas and this is something they would likely make.
    • You know what, I'll double or nothing. Save your money, buy a V8 Manual Mustang in 2 years and have a more fun street car with better support and all that. I often tell people "if I could do it all again, I wouldn't". Sell your R34 GTT to someone, spend the 20k in difference between that and a 2018 Gen2 V8 Manual Mustang. I'll bet you will have the $ in your pocket by the time you spend the ~20K differential on mods and get them installed. Just planting this seed for future regrets. Blah blah, wisdom of people who would do it differently who are at the end of the road you are just starting on, etc. Car modding is often death by a thousand cuts as you wait to afford the next big mod. Imagine a 2 door Skyline with a 330KW N/A V8 Revving to 7500rpm like the RB25, with 315's all round.
    • Yes I'm going through a similar thing with my R33 with rust in seams due to dried out seam sealer cracking. After much research I settled on Penetrol. Read what it does and its done a bloody fantastic job for me. Pressure pack comes with a thin tube to get into hard to reach places.
