just wondering, which is the preferd AFM for large turbos on RB25's?
the Q45 obviously has more flow because of the 90mm neck but apparently their low down resolution doesnt compare with the Z32, making the control at lower throttle levels not great compared to the Z32, how true is this? what would you prefer out of the 2?
https://www.sau.com.au/forums/topic/96397-z32-vs-q45-afm/
i was just asking of a general nature, which is more preferd/ more reliable/ more efficient.
but, my setup is a RB25DET 5 speed with custom high mount manifold, garret GT3040 with external tial gate, 740cc nismo injectors, greddy intake( thats the only thing i havnt got yet, cant bloody find one, if you have one PM me! :) ), large front mount, full exhaust.. i think thats about it ( its still getting built, all this is in my 1973 240z)
any recommendations :O
https://www.sau.com.au/forums/topic/96397-z32-vs-q45-afm/#findComment-1747477
That rumor is crap. At low revs, my car is fine. Not one single problem with the Q45. Idles like a dream.
Now, The Garret GT30 has a 4 inch intake. Why in the hell would you want to come 4 inch off the GT30, then drop the size of the piping to 3 inch to a z32? Can anyone say "bottle neck"?
Since the internal diameter of q45 is about 90% of 4inch, you lose very little intake size, meaning you can keep a nice big 4inch size all the way through.
I bought a Q45 for $180, and it runs fine, no problems at all. Z32s are the same or much more.
Also, You'll be able to use the q45 for your 380rwkw project...lol
Edited by The Mafia
https://www.sau.com.au/forums/topic/96397-z32-vs-q45-afm/#findComment-1747661
Hey bryce
Told you it sounded like crap to me. Remember 50% of what people tell you when they are trying to sell you something is bullshit =)
Anyway the guys here are allways keen to comment...
I got a Q45 afm too :) so its all good now since this is all cleared up.
https://www.sau.com.au/forums/topic/96397-z32-vs-q45-afm/#findComment-1748272
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
