just after inforamtion on the rb25de..
would like to get some information on the 33 gts? I will be upgrading from a xf fairmont..
What is the rb25de like on fuel? would the fuel be anywhere near a vx Commo s pack would it be anything near what that uses. newest 6 i have drivin and no what the consumption is..
did a little search and came up with
How many k's to a tank? is around 450km about right?
What are parts going to be like for the car. still dont know this one
Being a non turbo what will insurance be like do they still ask for a bucket load for a non turbo. not sure on this one
Performance wise how would it go compared to the Vx s pack?.
What would the avg 0 - 100 1/4 time be? i found around the 8 second mark? and a low to mid 15 1/4?
any other genral info would be much apreciated
Also am after a non turbo just i can get into the turbo scene and not payout my arse hole with insruance.
Edited by nugget666
https://www.sau.com.au/forums/topic/96409-information-on-33-gts/
I picked my r33 GTS up last week and it's bloody nice :O
( I haven't driven a turbo'd car before with 15psi or what ever it is that people classify as fast) but, it still goes very nicely..
Fuelwise, I'd say it's pretty good.. but the fuel tank is kinda small so that might make you think you're blowing quite a bit of fuel..
I was never a fan of 33's.. but seeing them in person and having a good long look at them I learned to like them a bit more.. :)
I recon parts would be pretty easy.. i needed new shocks just went down to the local mechanic and he hooked me up.
Don't know any facts and figures though about 1/4's
About 450kms per tank is correct depending on mods and how you drive obviously.
I haven't taken mine on the 1/4 mile or dyno so I'm not sure but stock should be around 90-100 rwkw (142kw at flywheel). The info that you posted about 1/4 mile and 0-100 times are pretty much correct though.
I'm paying $1380 on insurance for a '94 GST Coupe, I'm 20 and have a clean record, the only mods I listed were $2500 rims.
You shouldnt have too much trouble with parts as 33's are very common imports now.
For insurance if you have a misss and a house you will get a discount if you use the same company but if you are under 27 some wont insure you
no turbo will be alot better tho
50 litre tank and you sould get if serviced and looked after you might get it to 10l per 100kw
Get an exhaust and extractors and they sound pritty nice
james
18 at the moment.. turn 19 in march
hope to have a new car sometime from now to then
Not sure though ... i want somthing with some guts but not to keen on a turbo as insurance is heaps. I guess i should take a test drive...
Edited by nugget666
I've got a bog stock GTS25 ('93 model) with O2 panel filter, fuel economy out on the highway gets me around 10k per litre (550 - 600 safely on full tank), around town 6ish (300 - 350 safely). BTW you should have a 65 litre tank, not 50 as mentioned earlier.
    • Nah, you failed to pay your washer cover subscription and BMW have revoked your access.
    • Haha thanks Lith,  So it's currently working quite well and the torque reduction is setup and working phenomenal. It also got a custom torque convertor from All Fast in WA. Stall speed somewhere around 5500rpm unlocked but still with the lockup. The car went back onto the dyno after a 3yr hiatus (even with the dbw, and other mods completed in this time) managed to make ~515kw at all 4 hubs. Sean setup the Torque reduction which now sounds awesome and working well. We setup adjustable torque controlled launch control aswell.  Man what a feature. Especially when drag racing on street tyres I Managed to get out to the drags late last year and tick a huge bucket list item off of running mine and the cars first 9. Car went a 9.98 @142 Still had the young fellas car seat in the back aswell.  This was on 255/40/17 Nankang AR-1.  Currently the Turbolamik is still completing it's own torque calcs and managing shift times from there. Unfortunately emtrons can export is still a little restrictive to export the ecu calculated torque just yet but I have recently been suggested a work around that I just haven't had a chance to trial yet.
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
