To ALL,
In the column to the left of my posts there is a warning % meter and a lot of other guys dont have this feature?
Also noticed in the past wks that the total posts made by indiviuals is missing from this area as well? Just interested to know.---
Regards,
SKYLINE...(Kym) B)
https://www.sau.com.au/forums/topic/96437-how-come/
imo, showing the # of posts just encourages people to post crap, simply to increase their post count.
as for the warning... i dunno what that is. perhaps mods can warn people of bad behaviour or something :)
It appears to only show your own warnings... not everyone elses.
Edited by GFXman
https://www.sau.com.au/forums/topic/96437-how-come/#findComment-1748046
that's exactly right GFXman, the postcount was removed because it made things easier for postwhores to keep tabs on how they were doing against other postwhores.
You can still check the postcount by going into your profile, if you really want to see what it is.
As for the warn meter, all users have this, but you can only see your own meter. Only moderators can see all users' warn meters. All moderators are able to add and to remove to your warn gauge, and depending on what you o they can use it to place you under review (ie all your posts have to be approved by a mod prior to appearing on the forum), or suspend your account (make you unable to post of a period of time).
https://www.sau.com.au/forums/topic/96437-how-come/#findComment-1748076
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
