The last few days I've had ALL the warning lights flash on at night. I've had good oil pressure, plenty of oil, good engine temps, nothing seems to be wrong... It has mainly happened when either trning hard, or accelerating hard. ALL the lights come on, even the spare tyre light and windscreen washer light...
Anyone else had this happen? I'm guessing theres a loose wire somewhere maybe?
https://www.sau.com.au/forums/topic/96447-dr30-dash-warning-lights/
I had this happen the other week, check the wiring from the alternator to the starter motor and make sure that the but is done up tight!! Mine was earthing out on the support bracket for the plenum and causing all my dash lights to stay on!!!!
Yeah i've had 3 alternators go in about 4 months, got one rebuilt and haven't had issues with it yet, but i don't drive it as much anymore so who knows....
No idea what an alternator is worth Adam, go suss some places out ring around easiest way
Yeah pretty sure it is close to one, just have to change the wiring or something..
I got mine rebuilt by s&b auto electricals, Jacobsen cresent, instead of turning right to go to jaustech, turn left and its behind a furniture place up there if he's still there, if not i'll get the addy of my old boy, he's a mate of my dad's so yer....
same thing happend to me on friday night. 5 mins before i got home my alternator stopped charging, the power cable form the alt to starter had fried...replaced the cable and all is sweet now!
  • 1 month later...
It sounds like the regulator is stuffed though. The alternator should be putting out ~14V throughout the rev range. You aren't doing your electrical system (or your battery) any favours by driving it.
I bet your headlights brighten up nicely when you give it a rev, eh? :P
Depending on your alternator, you will either have an internal or an external regulator. From the factory, they had an external regulator (if memory serves).
My l20et's old alternator used to do this. I was told it was the Rectifier by a few auto electricians. I got another alternator for free and thre it on and it solved alot of problems i had with the vehicle.
My lights are dim as hell, I thought it was getting buggerall voltage, thats why I thought the alternator was stuffed
they probably are getting bugger all voltage, but its more likely down to the crappy old switch gear and low amp cable to the headlights in the factory loom. rewire with relays and serious cable.
changing the alternator is a drive way job son, should take about an hour or so, i wouldn't be stuffing around with changing regulators, if you've got a number for the alternator just get a new alternator, and keep the other one for a spare
  • 3 weeks later...
hey so does anyone have any part numbers for replacement alternators.. or spare parts or anything??? mines now cooked for the second time, only got it rebuilt a couple of days ago, and it died within a few hours of driving...? what gives?
to my knowledge it was rebulit with aussie parts from an MR30..
also does anyone have anything lying around that i might be able to buy as a replacement?
cheers.
dave
also does anyone know of any other alternator off a different vechile that happens to have the same connection at the rear, and same bracket mount points.. because if i can id like to install something with an external regulator to enable the ease of service again at a later date.
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
