Hi all.
Just wondering if anyone has come accross this in the past and can offer some advice.
My car was stock standard, and every once and a while (maybe 20% of the time i gave it a flogging) I could clearly hear the engine pinging all through the rev range. I later put a big exhaust and bleed valve to crank up the boost, and had it dyno'd and tuned to hopefully fix pinging. On the dyno it ran fine, but when driving it still pings about 20% of the times i floor it.
Has anyone come accross something like this and can offer some advice as to likely causes? Thanks.
(Skyline R33 GTS-T Series 2)
Edited by McBain
https://www.sau.com.au/forums/topic/96532-intermittent-pinging/
ur cas would be too advanced, injectors could be slightly blocked, spark plugs arent completing combustion, blah blah blah.. theres quite a few reasons why engines ping..
as above changing the tuner would be a good idea, and make SURE you mention u want the pinging problem fixed.. dont jus take a chance that theyll know its pinging as when they have the car it may not do it for them..
:P
  McBain said:
Thanks guys.
I will book it in and see how they go.
What petrol are you using? it could be as simple as that. These engines need to good juice, dont be buying the local sh!t on the corner. u need a 98RON fuel e.g. BP ultimate. i had the same problem when i first bought my car and wasnt using the top stuff, and it only ever pinged when i gave it some revs.
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
