R33 GTS-T Auto
Pod
FMIC
EBC
High graph = high setting on EBC
Low graph = low setting on EBC (max 175rwkw or so)
As you can see, the high setting is poor on the lower end.
Does anyone have any suggestions on ways I can solve this issue?
https://www.sau.com.au/forums/topic/96547-analyse-my-dyno-graph/
wink i friend of mine is running a WOLF 3d in his auto as it has the out puts to run the auto (but i'm no fan of the wolf)
SAFC 2 would be my suggesting, not to $$ second hand and in the right hands can be tuned pretty quickly for reasonable results. Plus with fuel prices like they are now it would most likely paid to get it done. Whats your fuel consumption like with the map running 10:1 when i would think 12.5:1 would be much closer to the mark for a light tuned rb.
pete
The PFC also has "outputs to run the auto", no big deal there. The problem is no aftermarket ECU (that I have found) has the shift logic programmed to cut/retard the ignition on gearchanges. I have driven autos with Motec's, Autronics, Wolfs and PFC's and none of them have decent shift quality. They are all very jerky at low throttle openings and have lots of slippage at larger throttle openings. The more power, the worse the slippage. All but one have now had gearbox rebuilds in fairly short intervals.
In the Stagea I have a Jaycar DFA for fuel tuning, a Jaycar IEBC for boost control and an Apexi SITC for ignition tuning. That's a glove box full of piggy backs, but the gearchanges are as good as standard and the gearbox is still alive and kicking.
:P cheers :)
Emanage is better than safc cause you can get it with a ingnision timing
harness
now after that you will need a shif kit
fuel pump reg and injectors
make a box for your pod
hiflow turbo
good for 220rwkw at least on a good turn not maxed out
james
Wink - easily said, as others have but you seem to be missing the point.
PowerFC - dont bother, its possible, but with major side affects you dont want
S-AFC - is what you want and will fix your problem with a little tuning
Wink also is that with your foot flat on the floor to get full throtal
when mine was at 12psi it would pop
i have set it to 10 and now my power band is heaps better
stock ecu cant handle much more than that nether can the turbo
no mention of an exhaust system
james
I forgot to mention the car is also running a 3" turbo back but only stock cat.
It seems general consensus is that a SAFC is the way to go.
However miller brings up the GReddy E-Manage.
The E-Manage costs around the same as a SAFC so can someone give me a quick comparo of the features/differences.
In the end, E-Manage (with Ignition harness) vs SAFC + ITC.
Thank you all for your informative input. Appreciate it! :(
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
