I had the factory Reinforcement bar modified to suit the FMIC. was a very neat job too.
However when I went to another place to get the front bumper painted and fitted they removed the Reinforcement bar to fit and attached the FMIC to the headlights.
Now the front end of the car is drooping and not looking good.
Some places will make a custom bar to support the intercooler and fit whatever bumper you have.
In my opinion in the long run it's best to have all the support you can.
Funny enough, i just discovered the other day that mine has been hacked off. I tool the front bar off (to do some repairs.... big chunk of skirt ripped off coming out of my driveway, as i had to turn sharper due to a c0ck in a 4wd opposite me!!!)
But yeah, middle section has been cut, between the headlights... my front bar hangs a bit too..
And i don't have a front mount!
I've seen a couple of bumpers on occasions where the original area where the number plate sits gets cut out to get more air flow to the FMIC and the number plate side mounted. This could only be done if the front end support bar is removed or hacked away.
I imagine leaving it off would not be the greatest idea because of the damage that could be sustained in a front end collision but it allows a FMIC to be fitted much more freely less weight in the front end and different bumpers can be fitted without exposing the front end support bar.
Wonder if I should remove mine....
i fitted my cooler over the wkend and i had to undo the two bolts on each side of the re inforcemnet bar n lift it slightly foward to get my cooler to site right...
Also to get it in with a stock front bar i had to cut out around the mouldings in the centre (where the actual cooler sits) and under the spot lights/blinkers i cut out a around 80mm out so the piping could run properly and the front bar sits as per factory
I would suggest leaving the front reo bar on and just cutting it a LITTLE BIT.
If you run up someones arse while driving u are going to do untold damage without the bar in place.
Remove it at ur own risk but i know that i wont be doing it on my car :)
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
