I have a whole heap of stuff laying around guys.
Q45 AFM, will throw in a JR pod filter (K n N equivelent) $150 FIRM
R33 GTR Vspec Stock Supension in excellent conidtion $300
Gizmo Dual Stage Shift light $60 Firm SOLD
Most 33 Interior Trim pieces, roof lights
Rear Seats good condition $50
Standard GTR Turbos (one needs to be rebuilt)
The other is in excellent condition, no shaft play
would be good for an NA conversion. Sell as pair $200
Standard GTR Dumps $40
Bolt In cage for 33, missing main hoop and some brackets $150
33 GTST rear calipers and rotors in good condition $150
33 Center Console $50
Chipped programable R32 GTR ECU (suits 33's aswell) $100
OBX Reclining bucket seats (never used) $350
QLD PLATES 94SKY $500
All parts located in brisbane but willing to ship interstate at buyers expense.
Please PM or call john on 0417 608 538.
https://www.sau.com.au/forums/topic/96576-garage-sale-r33-bits-and-pieces/
roll cage is a jap style one, goes around the dash but you need to drill holes to mount it to the floor.
by battery cover, u mean the plastic/carpet thing that seperates the hollow under the parcel tray to the rest of the boot?
if so $50 with shipping.
With the q45afm
obviously they don't bolt straight up to ya air flow box
can ya by flanges to make it fit , or just try and do it yaself .
i have 187rwkw, and going to be hiflowing a stock turbo
would you think this would be a good afm to put on ?
i'll be heading into 230rwkw later on.
THanks
sorry buddy, just trying to reply to everything inbetween work, dont have internet at home so couldnt reply on the weekend. Will do now though.
R
Do you have the plug for the Q45?
Is the rear calipers 2-pot?
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
