How do you know if its running lean?
It will ultimately lead to detonation and cause damage I.E melt a piston for instance.
If its running lean I would be tip-toeing it to my tuner/mechanic. There will be a reason its running lean (faulty fuel system diagnosis, poor tune, etc)
Unfortunately cant post it up as i dont have a scanner currently, so if it helps i will just write down the details below the graph, dont know if its correct, if not, just let me know what to look for, thankx.
BP:100.0 RH:48 AT:26 IT:48 RR:013 TN:3.768 CK:633
hi guys, im just organising the graph, and im in the process of having to change my airflow meters, cause i dont know if any1 else has the problem of the car cutiing out (not turning off) just a jolt etc. It only happens 0-2400rpm, whenever boost kicks in its ok, never have a problem.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
