Sauwa Chrissy Crooze 05 Sunday 11th December 2005
  • Replies 98
Josh can I score a lift with u dude? Im just a few mins away.. * Roleystone*
Hahahhahaa...
Will try and sort something out but if anyone lives near Roleystone area please pm me if you can give me a lift.
