Sauwa Chrissy Crooze 05 Sunday 11th December 2005
  • Replies 98
Don't think i'm coming anymore, I've been talked into doing a modelling comp instead haha. I've never done one before :D kinda freakin out....
Hope you all have a good time, guess i'll meet ya's at the drag night instead :)
I cant go ladies and gents my car got broken in to and busted up abit and work stuff stollen
has realy f**ked my life up at the moment
the liner is ok tho they f**ked up the bunky but i am in deep shit
sorry
james
Hey! Whats the dillio? I went down and there (there at about 12:40pm) and nobody was there :)
I saw 4 Skylines (3 R33's and a GMG R32 GTR) drive past and not pull into the truck stop and then I just drove home at 1pm.
Was I at the wrong truck stop?! :)
when we finally caught up with the rest of the cruise... that commodore was insane!
edit: i thought i couldnt see your car there topaz.. maybe you should have followed those skylines where ever they went? :)
edit: i thought i couldnt see your car there topaz.. maybe you should have followed those skylines where ever they went? :(
one continued on down Kewdale Rd, two continued on down Abernethy and the other went the other way down Abernethy :):)
I went for a drive down Kewdale and Abernethy and couldn't find any other truck stops....did everyone go to the truck stop on the corner?
