I bought my R33 GTR from AJM recently,
I think I got a good deal however I did have to threaten to sue them when they wanted to cancel before i picked the car up. ( probably because they had a better offer )
When i picked the car up the $400 per tire yoka's on the back were bald.
Gee I wonder how that happened .........
Also the gearbox had automatic transmission fluid in it to mask some kind of problem but it seems ok now.
Loving the car now tho
sb..
try autoforce imports ive bought all my cars all 9 of them previously from them kevins always looked after me .. i suppose your after a non turbo GTS? he has both atm cehck out the web site give him a call www.autoforce.com.au
BUt i would steer clear of both AJM and street machines..
the guys at ajm bouy cars off the trading post .. green compl and very dodgy !
Edited by 53XYN
man, your dad is a mechanic, dont forget this, you can take him with you, and he can throughly check over the whole car even organise a day for him to take the car to his workshop and check it out. id go private, just get your car checked very good, and maek sure all parts are in good working order. i know why u want a GTS for and that is understandable for your age, a very sensible option i think. but use the number one thing that u have on your side, a family member that has mechanical knowledge. that is your best way to go, all car will have sum sort of problem some time in there life, its just a matter of time, but if you do this it will minimize the risk of anything bad happening to your car in the future from parts failure. so get crack in and find your ass a new ride! :D
Yeah i intend to take my dad with me.. i was just wondering what dealers are down in brisbane.. i would rather get it of privete sale.. as its that tad chreaper but odsnt offer a warrenty.. But in the end oif the day i my warrenty will no doubt be void when i put mods on it.. so maybe i can say keep the warrenty knock a bit of the price..
o WEll buying a trading post thsi weekend.
should warn you guys about publicly slandering a buisness, should really keep all bad encounters to either PM or dont name the buisness in question.
I do realise this, and I realise that by saying what I did is dangerous. But seriously, after what they did to us, I don't give a shit anymore. I am more than happy to give people several chances at being decent people. Hell, anyone that knows me can vouch for that! But they just went too far, and I know they did it to people before us, and are still doing it today :P.
Anyway, this thread isn't about them, it's about us giving the names of GOOD dealers in Brisbane... sorry I couldnt be of more help than just Autoshop and SVi :lol:
I have a mate whos girl friends sellin a gts, he only told me bout two days ago, he rekons its in a1 nick, never seen it or nor do I know why she's sellin it but if ur keen to take a look send us a pm and I will tee it up and get her number to you
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
