Hi all, my car was stolen from West Gosford some time in the last day, it looks lke this:
if ANYBODY sees it or anything that resembles it (basically, there's no other car that really looks like this around) then PLEASE email me on [email protected], give me a call on 02 4962 1800, or send me a pm. the number plate is KW11CK, there's not much else to say on the car really.
fingers crossed... :O
https://www.sau.com.au/forums/topic/96655-car-stolen-nissandatsun-280zx/
Sorry to hear about any car being stolen. I know its not a good feeling, eespecially when you've put lots of time and effort into it.
I'll keep an eye out for it. I don't think I'll have any trouble recognising it.
Just out of curiosity, what kind of security system did you have on it?
yeah, is a nice car :P pretty bad story really...
it didn't have a full security system, i thought it had the stock zed alarm but obviously not, a lot of the zeds came with alarm systems that were designed to go off if someone played around with the wiring or anything like that... unfortunately the 2 other 280's that ive owned have had this feature, and the nice one happened to not have it (i can only assume). problem with these older cars is the wiring can start to play up a bit, so i don't know if that accounted for anything... it's just all the bad variables thrown into one really... wouldn't wish it onto anyone
So do you think its possible that joy-riders took it?
I wouldn't think they would in a car that stands out so much but it is possible.
Just in case it might be a good idea to check the areas people usually dump cars on the coast. If you haven't done it already.
It's a fairly loud car too, so they'd be noticed pretty easily if they were joyriders.
Hope you get it back, Matt. All thieves should be shot.
don't give up. had my car stolen about a year ago and it turned up 3 weeks later. it was dumped and had suffered a few thousand worth of parts stolen and a scratch here and there.
But i got it back.
I guess i was very lucky, but it can happen.
what did you do with the car once you got it back? i think i'd almost be more sad to get it back all bent out of shape, than to never see it again.
and yeah, i would agree that you were pretty lucky on that one. unfortunately I've heard that if you don't get it back within about 48 hours then you're likely to not get it back ever.
I repaired all the damage and kept it.
Or at least kept it for a few months. none of the damage was permanent and the car was 100% when i sold it.
I would have kept it for a few years but the buying of a house stopped that bit of fun...
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
