I recently had a problem with my front left headlight. For a while it was a little dimmer than the right, now, nothing at all.
I have tried playing with the connections at the back to see if it had just come loose, but nothing. So i had a look at the right headlight to see if anything was different.
Now i have no headlights. Sorry i mean no low beams. Parkers and high beam are fine.
Any help. How do I take the headlight assembly out and check it properly?
https://www.sau.com.au/forums/topic/9667-headlights/
Another obvious question checked fuse's( but a blown fuse might affect the high-beam too) so it must be the globes.
http://www.skylinegts.co.uk/R32-Fuses.htm
Has the layout but a test light is the best way to check fuses and also to check that it isn't a blown bulb!
Other than that it might be wiring/relay/earth?
The dull headlight sounds like globe fault/faulty earth to me!
The fuses for the headlights are in the engine bay in the relay box, two blue 15A ones!!
Also when ever taking out a globe don't touch the glass part!!(If you do touch the glass part clean it with dry cleaning fluid and a nice soft cloth before you reinstall it!)
MEGA
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-147314
Hmmm... i've always wondered why they put the massive emphasis on that?? I've touched headlight globes before, whacked em back in and no problems whatsoever. Sure, you don't want to leave big oil marks over them from your skin - but i've always just cleaned it down with my tshirt or something and no probs
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-147822
my friend has similar problems with his 32 gts .. one of the lights dont' work some of the time ... and sometimes it works correctly ... he wants to know where can you find the relay which the light uses??
Could be due to the switch (the stick you turn the headlights on with). I had a similar problem on my R31. It was pretty intermittant and eventually just went out together. And yes, the switch does have left/right wiring inside so one light can go and not the other.
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-147971
Its most likely the globes. You will probably find when you remove them, they will have a lovely silver mirror finish on the inside of the glass - that would explain the gradual dimming of the LH one at least.
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-152263
I have the same problem.
My front left works every now and then, ive swapped bulbs many times, which so far hasn't made a great deal of difference...
Its really starting to shit me off, if the light doesn't come on, i bang the glass covering, and it will come on 99% of the time.
My turbo timer has now ****ed up since last nite, (won't keep car running), so im thinking ive got an earthing problem somewhere.
Any tips on how i can check,
a. earthing (where and for which part)
b. the switch for the headlights
The other bit thats pissing me off, is im using the globes that cost $50 for 2. Now when these go pop for no reason after a day...
Im running a pretty powerful amp, could this have anything to do with it? (the headlight was giving me shit b4 all this went in however).
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-154149
there is no relay for the headlights on an R32, its all through the switch, mine does the same thing but im waiting till the w'end to take the switch out to clean the contacts in the switch, the problem can be caused by arc-ing in the switch which leaves hi resistance deposits on the contacts hence the no low beams
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-163350
therees a shroud thing around ur gagues, that has about 5 screws holding it in, after removing these screws, you need to unplug the looms from the switches mounted on the shroud, there are five or six plugs that need to come off, also it may help to label where the plugs came from (lights, foggies etc...) after the shroud is free, you may need to lower the steering wheel to free shroud, the switch can be removed, by undoing another four i think it is screws, then the switch will come out
but remember, the car is very well screwed together and there can be "hidden" screws that you may not see at first glance, dont want to break anything
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-167092
My R32 had dodgy low beam when I got it. First the left would go out then the right. Turned out to be the switch. Removed switch as SupaFly Skyline described after I found the screw hidden by the under-dash turbo-timer. After gently prising open the switch I cleaned the burnt looking residue from the contacts with fine wet and dry sandpaper and sprayed them with contact cleaner. Then I cleaned and lubricated the sprung detents. While the switch was open I replaced the blown indicator bulb inside (fiddly). Back together it works perfectly. No more problems X (fingers crossed).
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-167427
Ok,
first things first, this is not a 10 minute job :)
Ater ripping everything out, i cleaned up the contacts by sanding them down, spraying some wd40 on them and put it all back together. Everything seems to be working ok so far, so ill see how it goes over the next few weeks.
Thanks to every1 that provided info :P
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-169052
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
