I recently had a problem with my front left headlight. For a while it was a little dimmer than the right, now, nothing at all.
I have tried playing with the connections at the back to see if it had just come loose, but nothing. So i had a look at the right headlight to see if anything was different.
Now i have no headlights. Sorry i mean no low beams. Parkers and high beam are fine.
Any help. How do I take the headlight assembly out and check it properly?
https://www.sau.com.au/forums/topic/9667-headlights/
Another obvious question checked fuse's( but a blown fuse might affect the high-beam too) so it must be the globes.
http://www.skylinegts.co.uk/R32-Fuses.htm
Has the layout but a test light is the best way to check fuses and also to check that it isn't a blown bulb!
Other than that it might be wiring/relay/earth?
The dull headlight sounds like globe fault/faulty earth to me!
The fuses for the headlights are in the engine bay in the relay box, two blue 15A ones!!
Also when ever taking out a globe don't touch the glass part!!(If you do touch the glass part clean it with dry cleaning fluid and a nice soft cloth before you reinstall it!)
MEGA
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-147314
Hmmm... i've always wondered why they put the massive emphasis on that?? I've touched headlight globes before, whacked em back in and no problems whatsoever. Sure, you don't want to leave big oil marks over them from your skin - but i've always just cleaned it down with my tshirt or something and no probs
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-147822
my friend has similar problems with his 32 gts .. one of the lights dont' work some of the time ... and sometimes it works correctly ... he wants to know where can you find the relay which the light uses??
Could be due to the switch (the stick you turn the headlights on with). I had a similar problem on my R31. It was pretty intermittant and eventually just went out together. And yes, the switch does have left/right wiring inside so one light can go and not the other.
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-147971
Its most likely the globes. You will probably find when you remove them, they will have a lovely silver mirror finish on the inside of the glass - that would explain the gradual dimming of the LH one at least.
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-152263
I have the same problem.
My front left works every now and then, ive swapped bulbs many times, which so far hasn't made a great deal of difference...
Its really starting to shit me off, if the light doesn't come on, i bang the glass covering, and it will come on 99% of the time.
My turbo timer has now ****ed up since last nite, (won't keep car running), so im thinking ive got an earthing problem somewhere.
Any tips on how i can check,
a. earthing (where and for which part)
b. the switch for the headlights
The other bit thats pissing me off, is im using the globes that cost $50 for 2. Now when these go pop for no reason after a day...
Im running a pretty powerful amp, could this have anything to do with it? (the headlight was giving me shit b4 all this went in however).
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-154149
there is no relay for the headlights on an R32, its all through the switch, mine does the same thing but im waiting till the w'end to take the switch out to clean the contacts in the switch, the problem can be caused by arc-ing in the switch which leaves hi resistance deposits on the contacts hence the no low beams
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-163350
therees a shroud thing around ur gagues, that has about 5 screws holding it in, after removing these screws, you need to unplug the looms from the switches mounted on the shroud, there are five or six plugs that need to come off, also it may help to label where the plugs came from (lights, foggies etc...) after the shroud is free, you may need to lower the steering wheel to free shroud, the switch can be removed, by undoing another four i think it is screws, then the switch will come out
but remember, the car is very well screwed together and there can be "hidden" screws that you may not see at first glance, dont want to break anything
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-167092
My R32 had dodgy low beam when I got it. First the left would go out then the right. Turned out to be the switch. Removed switch as SupaFly Skyline described after I found the screw hidden by the under-dash turbo-timer. After gently prising open the switch I cleaned the burnt looking residue from the contacts with fine wet and dry sandpaper and sprayed them with contact cleaner. Then I cleaned and lubricated the sprung detents. While the switch was open I replaced the blown indicator bulb inside (fiddly). Back together it works perfectly. No more problems X (fingers crossed).
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-167427
Ok,
first things first, this is not a 10 minute job :)
Ater ripping everything out, i cleaned up the contacts by sanding them down, spraying some wd40 on them and put it all back together. Everything seems to be working ok so far, so ill see how it goes over the next few weeks.
Thanks to every1 that provided info :P
https://www.sau.com.au/forums/topic/9667-headlights/#findComment-169052
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
